Top pic:Found a few more. Curious as to what the 3 wires go to. The other two connectors are tied in with the trailer wiring. View attachment 14282View attachment 14283
do you know what fuse rating for the constant wires are? thanksTop pic:
Two way connector is for the passive entry antenna for proximity tailgate release. Hard to see the other one, but there should be a 4-way connector in that vicinity, and it is for the TTPMS module.
Bottom pic:
Two of the wires are used to configure to aux switches, or constant batt+/ignition batt+. The other is for a topper third brake light.
They are configurable by what fuse you use for them in the aux PDC. The jumper wire connector in the aux wiring kit needs to be used on the connector under the steering column, also, in order to get the wires to “pass through” to the aux PDC. https://www.ramtrucks.com/BodyBuild...jGgHzAHGUTU0WB3rWuqSY7YmQ2vEhuBWBAGmP39EZ2yddo you know what fuse rating for the constant wires are? thanks
Yup.Another connector question: Is it safe to assume these connections are for heated rear seats?
View attachment 30962View attachment 30963
