Connector question
Chrisminx
Anyone know what these two connectors are for? They are behind the driver side front bumper right inside the fender liner.20210209_203404.jpg
I can’t see them clear enough to find out what they are for, but I can see them well enough to know that neither one is for fogs/park sense (both features are in the same connector). So far, nobody, including myself, has seen a 2019+ ram not equipped with fog lights and park sense have that connector present. This is what it looks like-
Found a few more. Curious as to what the 3 wires go to. The other two connectors are tied in with the trailer wiring. 20210402_145720.jpg20210402_145659.jpg
Found a few more. Curious as to what the 3 wires go to. The other two connectors are tied in with the trailer wiring. View attachment 14282View attachment 14283
Top pic:
Two way connector is for the passive entry antenna for proximity tailgate release. Hard to see the other one, but there should be a 4-way connector in that vicinity, and it is for the TTPMS module.
Bottom pic:
Two of the wires are used to configure to aux switches, or constant batt+/ignition batt+. The other is for a topper third brake light.
Top pic:
Bottom pic:
do you know what fuse rating for the constant wires are? thanks
Dig through the dash cam thread, there's pics of the upfitter jumper location and schematic details for using those blunt cut wires inside the cab if needed. also details on how to use the pass-thru circuit to bring an AUX switch back into the cab.
Another connector question: Is it safe to assume these connections are for heated rear seats?
