cell phone mount
CAPT BRETT
I HAVE A BRAND NEW RAM 2500 WITH COLUMN SHIFT. I AM TRYING TO FIND A IPHONE CHARGING MOUNT THAT WILL WORK WITH THE 12" SCREEN.
HAS ANYONE DONE THIS YET? LOVE TO GET THE HELP.
I use quad lock mounts for almost everything
Well i have a local shop in Dubai that made me a custom plastic mount with natural leather and stitching as well, and mounted the Brodit mount on top.
I will take decent pictures once I'm back home.
and btw there was no drilling at all to the vehicle's dash, it was all fixed with clips that gets tightened to the dash edges from inside.
Another solution to mounting your phone with minimal obstruction is the Rokform mount. They have different types but this is the one I used. It is a magnet on a swivel with a 3M adhesive strip that you can attach to your dash or any desired location. You can use a Rokform case or any other type that has a magnet or some type of ferrous metal in the back.
Not to stir the pot here, but why do you need a mount when your truck has a holder below the infotainment system and Android/Apple compatibility? We have those big beautiful screens in our trucks!
For recording while I'm driving with my phone camera or go-pro. Plus I have other stuff mounted up there as well
My phone does not fit on the holder unless I take off the case.
Just install a quad lock in my 3500. Used Ram ball mount so I can move the phone up out of the tray or down inside where it used to site (but god I hate the factory mount which always catches the charging cable). All those dash mounts get in the way of the column shifter.
I see Quadlock now has a wireless CarPlay adapter so I may give that a try with one of their wireless charging heads to ditch the cables.
I run a 7" Furrion Screen for my cameras, I did not get the RAM Camera system for my 5th wheel.
Well for starters....
1. The mount is designed to clamp/crimp on the bottom of your phone, if you have a larger case, it doesn't work.
2. The charging cable ALWAYS get caught in the grove under where the phone drops in, so while futzing around to get the phone out of the "mount" the cable gets caught and invariably pulls out, shutting down car play... arghhh.
3. The phone mount is facing the rear of the truck (it's square) so using the phone at all is a pain in the ass since it's not facing the driver, so you have to pull it out... then see #2... cable gets pulled out.
4. That big beautiful screen we have is currently have is mostly (1/2) useless to iPhone users since we only get to use half the screen and end up with a stupid display beneath it that shows Sirius Weather or whatever... heck you can't even display the radio interface nor the on-board navigation screen, all of those take over the CarPlay screen. God forbid you hit a camera button and it would use that lower section... nope it replaces the CarPlay display. Love to take the software engineer who made this out behind the building on day...
5. Apple designed Carplay so that you are forced to use your phone to enter addresses on the move (when Siri voice screws it up) since they disable the onscreen keyboard when the truck is moving.
Really it is item number 2 and 3 that drive me the most crazy though I gotta admit #4 was the most disappointing about the nice huge useless 12" display unless you are using on-board Nav. If only the camera system could take advantage of the entire screen... nope. Grrrr.
Now that I have a movable mount I'm much happier. To each their own eh!
