Can you upgrade to uconnect 5?
Thanks to rfullen280, I got my CVPM swapped out with the one he suggested and my cameras are back! (all but the 360). My Uconnect 5 still cuts out frequently however.
Radio module- 68507350AB
12” screen, depending on engine and lane assist feature:
Hazard button only (gas)- 68526608AB
Hazard/traction control (diesel)- 68526609AB
Hazard/lane departure warning (gas)- 68526610AB
Hazard/traction control/lane departure (diesel)- 68526611AB
Xm/gps antenna cable- https://www.amazon.com/StickyDeal-Volkswagen-Navigation-Telematics-Bluetooth/dp/B08JTYLNLR/ref=mp_s_a_1_2?crid=14J6856W5QEHO&keywords=male+to+female+fakra+z+1’&qid=1652103332&sprefix=male+to+female+fakra+z+1+,aps,227&sr=8-2
CVPM- 56029965AC
As far as programming/updates, you’ll just need to use AlfaOBD to change the model year in the BCM to 2022, and recalibrate the cameras for the new CVPM. I also have a copy of the latest software version for the radio that you can put on usb to update the radio module.
PM me for details on the necessary custom cables.
@Jimmy07 do you have a link to the steps for Alphaobd to change the model year so I can get my uconnect 5 working in my 21 1500 ram
Evening all...
I just found this forum. I recently upgraded a 2019 2500 big horn diesel from 8.4 UC4 to 12.1 UC5. I have made the necessary changes in the BCM ICS and Display and have back up camera blue screen ( Please check surroundings). Only camera on the truck currently installed is the backup camera. I swapped back to the 8.4 and reset the BCM to the original settings...backup camera worked. So i have isolated it a setting or the UC5 module itself. The UC5 upgrade had a 2023 manufacture date if that means anything. Any suggestions on what i should change? Thanks in advance. Brian
Evening all...
hi i have the same thing going on ever get a solution thanks
You might need a new camera module and or reprogram your current one to communicate with the newer system.
Hello I need some help, I have a 2021 ram limited I upgraded the Uconnect 4 to 5 screen, module and the newest CVPM. I ran all of the procedures and got top view camera to work. My only problem I had was the Lane Sense/anti lane departure and parking assist buttons did not work but hazard button does. I couldn’t figure this out and took it to ram so they could “have a look at it” and they used the WiTech tools and blew out all of my AlfaOBD settings. They sent the 2021 build to the 2022 screen/module. Left me with no backup camera at all. After 8 hours of playing around in Alfa I got everything back except now I have no cruise control. Because ACC and AEB are throwing error codes: “Adaptive Cruise Control # C2206-00 vehicle configuration mismatch” and
“Driver Assistance System C2206-00 vehicle configuration mismatch”
Please someone who figured out how to fix ACC, Lane Sense, AEB etc guide me.
I can’t live without cruise control, or backup cameras. I drive 3 hours daily. Cruise is a must. It appears if I change year of truck to 2021 then cruise and those errors go away but I lose my backup cameras entirely until I push 2022 year.
I also tried disabling ACC and FCW etc hoping I can get just cruise to work, no luck.
Side note how I fixed cruise before taking it to ram dealer, I went into steering and cleared 2 error codes and cruise was working. Now after ram dealer those error codes do not pop up anymore. Ram dealer told me they can only order me a new screen which would be 2021 to “fix” it.
