Yes it can be added and no wiring it takes some extra wiring @Jimmy07 can set you on the right trackMy 2021 Tradesman doesn't have the cargo camera, can it be added? I don't even know if the wiring is even there to do it?
Thanks
Thank you!!![]()
2019-2021 Ram Heavy Duty Factory CHMSL Third Brake LED Light Cargo Camera Kit
Do you own a 2019-2021 Ram Heavy Duty truck? Introducing the first plug & play Ram truck factory cargo camera upgrade. Keep an eye on precious cargo in the bed of your truck or make connecting to your 5th wheel so much easier! The 3rd brake lamp looks much better than the stock 3rd brake lamp...www.infotainment.com
Way overpriced that way! Dont do itThank you!!
I have a WIFI camera on my back rack and while it does OK for what it cost the OEM cargo cam is worth its weight in goldI like that idea, but if I add a headache rack it might be less expensive to use an aftermarket camera mounted there instead.
However, I want it to displ on my 8.4 (no nav) screen.
