Broken Third Brake Light
No I have not. It was a brand new light assembly. I know that does not matter. :) I also need to check on the canopy wiring because the third brake light does not work there either.
Do any of your brake lights work? Because the blunt cut factory brake light wire supplied for toppers is not tied to the same circuit as the CHMSL brake light wire.
I ended up ordering this one from Amazon and it is truly plug and play.
Thanks, I did also. I want to see if it all works again. I purchased AplhaOBD and Kaodtech security bypass also. I wanted to get it anyway.
I got mine installed today. It works. There must be a difference between the LEDS and standard bulbs.
