Bolt Pattern 2021 Dually with 12" Ring Gear
CdnHO
South Ontario and South Texas
Is the wheel hub diameter and bolt pattern for a 2021 dually with the 12 inch ring gear the same as the other duallies with the smaller ring gear? Scratched the crap out of one of my front aluminum rims and need to replace it. Hoping that someone might have a take-off they are selling.
2019 and newer Ram duallies have a 8 x 200 mm bolt pattern. Not sure what the hub opening size is. Older duallies are 8 x 6.5" (165.1 mm).
From what I’ve seen, the bolt pattern and hub diameter should be the same across the dually models, even with the 12" ring gear. I scratched a front rim too and used a take-off without any issue. Just double-check it’s off a 2021+ model to be safe.
