Blunt wires in rear. A500 and F606
Pond Brook
Monkton, VT
I'm a little confused. From what I am seeing, I don't have aux switches. However the wiring is still there. I found them in the rear, just can't seem to find them up front. Did they change the color mid way going forward?
How do I get power to these wires?
2022 Laramie Sport 2500
How many wires did you find?
The wiring schematic just shows a CHMSL signal going to the rear without aux switches. It should be WH/VT.
The wires can still be there but they are dead ends (only in a short section of the harness back there) without the fitter switches. Somebody smarter will explain it better.
I have the two power wires back there too. I also found and already tapped into the CHMSL wire. That was in the same blunt wire bundle. I have the rd/wh and pk/og wires. Curious where they end. Are they any closer to power up front?
Figure if they are there, might as well tap into them and make them usable.
i also have the blank fitter switches up front under the dash. Although I can't seem to find the correct color wires coming in.
On the trucks with aux switches those terminate under the dash where a jumper gets plugged in.
I found the jumper plugs, however none of the colors of wires match up to printed schematics.
Are you sure it’s the correct plug? There are multiple plugs under the dash.
