Beth - the every man 4.5 Power Wagon
Finally got her out… on the stock 33… I’m beyond impressed. I felt like I was driving a bigger version of the Gladiator Rubicon I traded in for this truck. I did put the Carli skid to work though, worked awesome. I won’t be doing this trail again in the Power Wagon, at least not without a few more inches of ground clearance.
A before and after of my install, the Rubitrek’s at 45psi are right under 33.5 inches tall for reference. It tucked under the bed just fine and balanced beautifully.
I used JSCAN and my Infotainment.com bypass cable to make quick work of recalibrating the tires. The ABS system didn’t like it, so I had to reinitialize it from JSCSAN. Here’s the screen shot for reference if anyone needs to run it. I know I had a mini panic attack with the lit up Christmas tree.
Anyways, this truck is just badass. Makes no work of anything I have to throw at it. Whether hauling, wheeling, commuting, camping, etc.
Phone mounts, steps until I can afford WKO sliders, the ARB compressor, switch panel, 35’s and seat covers are the only mods I’ve found myself needing after a year. I had done 12 by the time I got my Gladiator from the dealer with 0 miles 5 years ago.
Cheers to my poor man PW!
Has anyone ever gotten 35’s and hated the way the truck drove? I’m not a heavy footer so acceleration and braking aren’t what I mean. The truck just feels floaty, not sure if it’s the stock shocks? I used to run 50-55psi in the duratracs and have these set to 40.
You’re probably a bit high in the rear. In my Rebel I run 40 front and 35 rear “unloaded”, and that’s with a few hundred pounds in the back.
I’m sure in practice it’s fine, I have all 4 at about 42-44 depending on external factors. I noticed a little steering wheel shimmy although the truck drives straight at about 45mph. Makes me want to get the tire’s balance checked. I do think it made the truck somehow seem more upscale. I don’t think you lose any flex with 35’s so I don’t know why Ram won’t just throw throw these on from the factory.
That definitely sounds like a balance issue, or possibly a tire out of round. That does happen occasionally.
If you drive on a lot of grooved or rutted pavement the wider tires can make it pull more back and forth.
I noticed yesterday with the truck sitting on even ground, I could visually see the driver side tire is towed out by a few degrees. I’ll have that checked first then worry about rebalancing. I guess that would probably explain why it felt off at 60psi, better at 40-45 but still the same shimmy nearing highway speeds.
The Wagon finally went in to my shop. They adjusted the alignment as shown above, the tech still noticed the same non road induced steering wheel wobble, rebalanced the tires and it was corrected. I've been driving for a week since then, feels 1000% better. If ever in Southern Nevada, American Offroad Customs is my only trusted shop.
Your front toe should be set to 0. It makes a huge difference to handling and tire wear.
I'll have to look into it, I do feel a slight pull to the right, but sometimes I also feel it to the left. Could just be the wider tire and the road crowns as it isn't always there.
I'm through two full tanks on the 35's... gas milage obviously didn't improve but I can't really tell that it got any worse either. Fuelly said 10 my last fill up from 1/4 tank and that was with the same boring commute of mostly stop and go driving.
