H3LZSN1P3R
You're doing it wrong
Clearly your truck disagrees… lolIm fine the way I am.
Well I imagine that I’ll get better at it as I get more experience. I just got it at the end of august and the first time I towed the camper etc was last week. It’s my first hd and lwb.Clearly your truck disagrees… lol
My Tradesman has it.Its nice having a base model. Less things to not like or go wrong haha
Easy fix... all you need to do is make a jumper wire with two spade terminals. Plug it into the seat belt plug located under the driver's seat after unhooking the plug going to the seat belt.
Did this with both my 07 and 22 ram. The 07 was to get rid of the seat belt chime. The 22 obviously to disable auto park.
Pics?My 22 Laramie/gas has a switch to disable autopark in the overhead console.
Clearly you have never tried it….Its the icon with door open.
Is your foot all the way off the brake?To backup without seatbelt and door open.
If you are still on the brake thats why its not doing the auto parkNot sure, use it to maneuver around crowded build sites. Truck is a crew w/longbox.
ThisPretty sure you should only get the disabled alert in 4wd low.
I go through one of those type of car washes every single day that it’s not raining, and that’s never happened. I just wait until the very end when my front tires are off the track, and I just shift to drive without ever pressing the brake pedal.So…going through a car wash in neutral, get to the end and trying to shift into drive. I experience the same auto park but, I am belted in and doors closed. I’m avoiding car washes until I figure out what I’m doing wrong. I’ve been inches from causing a pileup in a car wash because I need to shut off the truck and restart.lol
Sounds like there may be a bigger issue at play that does not sound right at allSo…going through a car wash in neutral, get to the end and trying to shift into drive. I experience the same auto park but, I am belted in and doors closed. I’m avoiding car washes until I figure out what I’m doing wrong. I’ve been inches from causing a pileup in a car wash because I need to shut off the truck and restart.lol
It does, they built a new one locally that fits tall vehicles and I fit just fine.Your truck fits through a car wash?
