22PearlRamMegaHD
So far I've only had 24 hour regens outside that one mentioned above. On the tires I wonder if there's enough difference with what I'm running vs what you had run. I see they're about 3/4" shorter. I'm running Toyo Open Country RT.After DPF replacement mine functioned much like yours. For about 4 months. The regen issue is getting cranky again with a couple of low mileage interval soot based regens recently. I'm still getting passive regens, but they're taking longer and I have to work the truck harder. I run 295/70/18 and they never made any difference with my regen problems. I am happy for you that your truck is functioning more or less as intended, I was happy when mine was. Something is terribly wrong with these trucks and I believe the DPF is a symptom, not a cause. I know you monitor your truck closely, and I don't want to rain on your parade, but don't be surprised if it starts getting cranky as well.
One thing I have definitely noticed on archoil 6500 vs no archoil is that the truck seemed to have more get up and go at normal throttle with the 6500
