22PearlRamMegaHD
Got my Fleetguard report back, and let's just say the exhaust system/ dpf replacement makes me think it's not fixing the issue. Fuel dilution is 9.3%...
Yep. Insane.9.3% fuel in 2,800 miles?!![]()
The more I dig into this problem, the more I’m inclined to believe that many many more trucks have fuel dilution issues and the owners are unaware. Probably explains why the cams, lifters, and pushrods are wearing at an accelerated rate on some of these trucks.Yep. Insane.
Crazy part is I was able to grab the service rep before they closed up for the night. His initial response was they replaced the exhaust today and drove 40 miles with no regen. I told him that doesn't surprise me with a brand new dpf, but even with the regen frequency I had at 20-30 miles between regens 9.3% is way high. I suggested they check the injectors and fuel pump before returning it to me, amd with a shrug he said he'd print the report and give it to the tech tomorrow to see what he says
It figures, I ordered a twin pack yesterday.FYI Archoil is on sale, 10% to 30% off at Amazon 7/16 and 7/17 https://www.amazon.com/stores/page/...bUusdZiDXP_4SsIslsvm3Irz-mBPCFcHPL2exk.SwSu9D
Because the issue was caused by a warranty issue they are changing the oil before releasing it to me. Originally they were not, but I protested. I gave them a Donaldson filter to put on so I should be able to easily confirm the change.With over a quart of fuel in the oil, I would change it and then change it again shortly afterwards. That’s a lot of fuel for that few miles.
I would still change it again if for nothing else but a flush. I would do my best to give it a zero percent fuel to start.Because the issue was caused by a warranty issue they are changing the oil before releasing it to me. Originally they were not, but I protested. I gave them a Donaldson filter to put on so I should be able to easily confirm the change.
I would think that anytime there is something that they diagnose, that could contaminate oil, they should be replacing it anyhow. Unfortunately, your truck sounds like mine with the regen cycles.Because the issue was caused by a warranty issue they are changing the oil before releasing it to me. Originally they were not, but I protested. I gave them a Donaldson filter to put on so I should be able to easily confirm the change.
Zero chance that the particulate matter sensor had anything to do with fuel dilution. The sensor has absolutely no control over anything fuel related.Just looking for some input here. Service rep shared my fleetguard report with the tech. Tech says the fuel dilution is the result of the failed dpf that occurred due to a failed MAF (never threw a CEL) and lack of diesel particulate sensor. 2700 ish miles on the oil. 9.3% dilution. With a record of that 2700 miles showing a steep decline from regens at about 300 miles immediately following oil change down to every 20 miles for the last 200 miles or so before leaving with the dealer nearly 3 months ago. The only regens that went longer was when I was told to drive it harder or pull a trailer. So I pulled a 34' camper to my hometown and back about 350 miles each way, but it regened the few days I was in town before the return trip.
Do you guys think that dilution is possible with the above facts? I basically had to tell them today I'm making note of their refusal to check the fuel pump and injectors for failure before they relented and agreed to do their jobs.
This should be the way warranty work is handled, but unfortunately Ram / Stellantis penny pinches when it comes to wholesome and thorough warranty work. If the engine was covered by Cummins under their warranty program, I can assure you the engine oil would be changed anytime a failure occurred that represented the potential for engine oil contamination.I would think that anytime there is something that they diagnose, that could contaminate oil, they should be replacing it anyhow. Unfortunately, your truck sounds like mine with the regen cycles.
Cummins isn’t permitted to do anything or release any information to the public regarding these engines. They have some sort of legal binding agreement.Has anyone reached out directly to cummins on this issue to gather their take?
I understand the legal context.Cummins isn’t permitted to do anything or release any information to the public regarding these engines. They have some sort of legal binding agreement.
As far as Cummins Inc. is concerned, when it comes to the 6.7 in the Ram, it doesn’t exist the minute it leaves their factory.
Which is incredibly unfortunate because you’d get considerably better service and information if they were permitted to handle all warranty repairs pertaining to the engine and emissions system.
I guess it's a good thing I bought 6 gallons of oil last time NAPA had premium blue on sale...Zero chance that the particulate matter sensor had anything to do with fuel dilution. The sensor has absolutely no control over anything fuel related.
If the failed DPF caused regeneration to happen more often than it’s needed, then I can see where that may have caused some fuel dilution, however nearly 10% fuel in less than 3,000 miles is egregiously high. More than I would assume would be present even with frequent regeneration. I suspect you have a fuel system related leak. Either the HPFP seal or one (or more) injectors malfunctioning / dripping.
If they can’t provide evidence that they did indeed send the injectors out to be tested, or they performed one of a few different fuel related tests on the truck in the shop, I would have a hard time taking their word on it. 10% fuel dilution in under 3k miles doesn’t happen by chance alone, and I’d also have a really hard time believing that much fuel came from regeneration unless the truck lived in a perpetual state of regeneration that entire 3,000 miles….and even then, I would find it hard to digest. How many miles are on the truck currently?So the tech is saying there is nothing wrong with the HPFP or injectors but I suspect they didn't check them. Call me jaded, but I have a really hard time believing 10% fuel dilution in 2700 miles is possible with the regens i saw. I'm going to change the oil one more time when they release it to me, then change it again in 3k miles plus send out another OA to fleetguard. All this while monitoring the oil level with each fuel up
