Android Auto full screen without adapter on 2025+ models?
DubVBenz
Looking into getting a 2025+ HD Ram and was wondering if there has ever been a solution to full screen with AA? I see that some have used an adapter box, but I'm assuming that requires a wired connection. For context, I have a 24 GM 1500 and AA does full screen, but apple carplay does not.
Or 2026. Played around with developer mode as well with different resolutions but nothing. There is a box mentioned on another thread that possibly works but I haven't tried it.
I can confirm AA does not go full screen for the 26 still. Today I just ordered AutoLinkr which supposedly works. It connects to the wired Carplay and allows you to run AA at full screen.
Link? Might be the same one I mentioned above. Closed the tab a few days ago when I thought about buying it but can't find it now.
Did you get it to work?
I did get the AutoLinkr Pro to work. It was approximately $70 directly from AutoLinkr as they were running a sale. It took quite a long time for the initial setup/connect to the truck. I hooked it up with the included USB-C to USB-C cable to the #1 USB-C power outlet under the screen. It took so long that I almost gave up and started the return process. Not sure what got it to finally work, but I did manually restart the UConnect through the reset option on the screen. Once AutoLinkr finally loaded, it seems to work fairly well. At this point I have only had it for a couple of days. It does take a wee bit longer to load than just using AA on the Uconnect but not terrible.
I have my truck setup for the blindspot cameras to come on every time I use the blinker and I have noticed that when the camera switches off, the screen "glitches" to Device Manager then back to the Carplay screen. Also, it seems that Google Maps is always on the screen. Not that big of a deal, but I haven't been able to get either Spotify or Phone to go full screen. Google Maps always stays on the top half. I bought this for mainly full screen AA, so I haven't tested the Netflix/Youtube or other features this box has. Once I got this to work as I wanted it to, I velcroed the small box to the underside of the screen, out of the way.
I got mine last week. Didnt fill out the screen, 14", for me. Google Maps was unresponsive and same with Waze. Played around with resolution size in developer mode within AA but still wouldn't work. Sending it back to Amazon :(.
@RamCares this is a software update that many customers want. The GUI of the 14" screen by it's self could use a tune up. A lot of wasted space.
