Always on Camera Solution - NAViKS
Ok, thanks! Sorry for the questions but I have one more if you don't mind. So id have to wire the 65' cord that come with the camera through the truck and to the back of the radio to hook up to the rca inputs?
He sells quick connect kits as well.
Just talk to Tim and tell him what you need and he can get you setup.
I'm currently using the Brand Motion camera but am NOT pleased with it. Claimed 90° vertical view is a lie.
Should have stuck with rvcams good 90° vertical view camera as I originally intended.
Maybe @Phil T has a better suggestion.
Forgive me, if this has been previously covered, but I have been considering the naviks unit for about a year and have been monitoring this thread on and off during that time. I’ve been hopeful that they have gotten the kinks worked out of the system, can anyone comment as to whether or not they have worked out the turn signal problem, or any other persistent issues?
Separately, my concern from day One was the fact that when I put my truck into reverse, it changes the brightness of my display, consistent with a back up camera type of situation – you would want to see it, no matter if it was bright out or not so the system turns the screen to full brightness. Does this happen also with the naviks unit when you are driving with the camera or rca on? I asked Naviks about this over the phone and they said they were unaware of any thing like this, so I’m just curious if anyone here has installed the unit and use the always on with the screen blinding them while they are driving. I would assume that the brightness dash controls are not usable in this instance ?
same question as above. Can anybody comment how things are going with naviks these days? Is it recommended by anybody or is there a better alternative?
I have the same questions. I see they are now compatible with the '22-24 trucks. I just bought a new '24. Does anyone with a '24 have any feedback? I don't need to add extra cameras as I have everything I need from the factory, but I do like the idea of being able to pick a camera and hold it there, indefinitely so if I wanted to. Thanks!
