ylwrseoftx
Has anyone had any luck using AlphaOBD AlfaOBD to rewrite the levels for your stock air suspension? I really feel like mine (19 3500 HO SRW SB) are constantly over inflated. Doesn't matter if it's normal ride height or alt trailer height. It's just too much.
I've reduced air pressure in my tires, I've done the adjustable links (only way I could get the dang truck level left/right), these have helped a little bit. Ideally, imo, if Ram would change anything, it would be to have the stock air where you could adjust it as needed, loaded or unloaded, with a turn nob or something, but I digress....
I'd like to try changing the ride height in the system & see if that makes a difference. I'm not sure what the spec is supposed to be though (in mm) and which direction I would need to adjust them to. (Currently the left is at 4mm and the right is at -5mm) So before I go inventing the wheel, I was curious if anyone else has tried this route before?
