ColoradoCub
Cool thanks.Nope
Cool thanks.Nope
My convo with them attached. I believe it is supported…On the JScan website it says it’s functional with DJ 2500 2013-2022 however on the app it says DJ Ram 2500 2013-2021 can anyone confirm that it will work on a 2022?
So you just used the DJ Ram 2500 2013-2021 on your 2023 and had no issues?My convo with them attached. I believe it is supported…
No that wont work… that looks like an OBD adapter for older carsPretty new here guys and have a cable question. Will this cable work with JScan? And do I need additional cables? Thanks
2023 Ram 6.7
I guess I would need a kaodtech cable?No that wont work… that looks like an OBD adapter for older cars
That bypass will work, but it’s a pain to install on the HD Rams because it requires instrument cluster removal. It bypasses the security gateway directly by plugging those two connectors into the two connectors that are plugged into the gateway module.Pretty new here guys and have a cable question. Will this cable work with JScan? And do I need additional cables? Thanks
2023 Ram 6.7
Perfect! Thanks for the info @Jimmy07
