John Jensen
I never said or implied that the 68RFE was inferior. I'm just replying to the comments that the 68RFE is better than the Aisin, which is not true. You and Motor Trend both say the 68RFE can't handle what the Aisin can. FCA doesn't put a 68RFE in the HO because it can't handle the power. Most, if not all tuners won't tune without also modifying the 68RFE because it can't handle the added power in stock mode. Tuners can tune an HO and have no need to modify the Aisin.Except it doesn’t. In a stock HD with the SO Cummins, the 68RFE Will handle whatever you are doing unless you are towing over 18k daily. At that level of use the Aisin would be almost literally required. But for everyday common uses of an HD truck the 68RFE will do it’s job.
This quote from motor trend says it perfectly:
The bottom line here is: If you are using your Ram 3500 for "commercial" hauling and/or towing applications where trailered loads are more than 18,000 pounds, the Aisin AS69RC is the automatic transmission for you. But for the rest of the Ram 3500 6.7L pickup owners, the Chrysler 68RFE will do the job as intended.
I follow several forums and have yet to hear of an Aisin failure, but read of a lot of 68RFE problems that are usually corrected with modifications. I imagine the 68RFE has made RexMax a small fortune.
