Aisin shifts FAST, just doesn't feel "normal"
2021 HO with the Aisin...Running in T/H mode made my truck hold a gear much longer.
Running in normal mode, yes.. I was in 6th before 45 mph.
Long story short... I ran the truck in T/H 99% of the time, even unloaded.
I would be fine and dandy to run T/H all of the time if the downshifts didn’t get so aggressive.
The up shift schedule is great, exactly what I’m looking for.
TCM tuning is the only way to stay in the gears longer. Can't forget to mention the defueling the stock Aisin calibrations do, it bogs the truck down at 4th and 5th.. With my recent 2G swap and dyno tuning..for some reason this defueling was multiplied..I would loose all boost when going from 4th to 5th..damn truck would defuel, loose boost, then I'd have to rebuild boost and then it would sling shot....I was running on 4:10's with 37's. Using T/H mode would clean up a little....just didnt like the aggressive downshift..It works with a load behind her..but around town...no. Couldn't find a happy medium. It was annoying. So I re-geared to 4.44's and did TCM revisions. Truck runs great and shifts meh....could be better... It actually holds the gears longer now..doesnt defuel and fall flat on its face as before.......just with slightly higher rpms cause of the 4.44's...It actually tows better with these gears than the 4.10 did.
I'm actually looking at re-tuning the TCM with Calibrated Power's Aisin TCM tune. From what I understand from them, they are offering calibrations from mild to wild....I also looked at PPEI and spoke with them about their TCM tunes, and its basically a generic, increase line pressure, tune.
If you dont want to re-tune your TCM, you can alway manually shift it from the steering wheel....
Takes some getting used to for sure.
The past few times driving the truck around town I used T/H mode. For sure it holds gears and allows for more familiar acceleration, but YIKES the aggressive downshift is brutal with an unloaded truck. Like I said earlier, it sounds like its shifting as it was designed to shift, like it or not, and that was my main concern. So it is what it is. The truck was purchased to work and tow and for that purpose, it works awesome.
