Crusty old shellback
Hmm. Maybe that's the issue of why it will not fit.
As far as running balance beads and such, we run a balance liquid/tire sealer in the tires of our offroad race truck. It keeps them balanced and will seal a small puncture.
Truck will do 150 MPH across the open desert, so it works.
As for the goo clogging up the valve stem, I'll shoot a blast of air into the tire before checking pressure or releasing air. This is to clear out the valve stem.
Also I stand the tires up with the valve stem on the bottom and let the sun heat up the tire and the liquid flow out of the valve stem if there is any in there before doing the quick blow of air thru it.
