Adding air bags to a 3500
Xflight29
Was thinking about adding a set of Logigair to my 3500, by doing this would it affect the stock ride performance while not towing? by adding them, would it raise the rear of the truck from stock to a bit higher due to the mounting hardwear?
Since airbags have a minimum pressure there will be a slight increase in spring rate when you’re empty, but it’s pretty negligible.
The empty height won’t increase if you keep the airbag at the minimum pressure when unloaded.
How much sag are you getting now when towing?
How much sag are you getting.
