Active Noise Cancellation on 6.7L
<div class="bbWrapper">It&#039;s great for eliminating low frequency drones, especially when cruising on the highway. That said, mine is disabled as I replaced the stereo in it so it had to go. The truck is pretty quiet as is.<br /> <br /> Sent from my SM-G981U using Tapatalk</div>
<div class="bbWrapper">Harness is available to purchase from different vendors. It&#039;s no longer under the seat; located near emergency brake pedal</div>
<div class="bbWrapper"><blockquote data-attributes="member: 12894" data-quote="Grayson" data-source="post: 149560" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=149560" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-149560">Grayson said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Harness is available to purchase from different vendors. It&#039;s no longer under the seat; located near emergency brake pedal </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Doesn&#039;t that depend on which system is installed?</div>
<div class="bbWrapper"><blockquote data-attributes="member: 17080" data-quote="senecagreen" data-source="post: 149558" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=149558" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-149558">senecagreen said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Is it hard to disable? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>To disable the ANC only I don&#039;t think it&#039;s possible, to disable the ANC and upgrade your entire system (with aftermarket amplifiers and so on..) that is definitely possible.</div>
<div class="bbWrapper">You can disable the ANC without total system upgrades. Some people disconnect the mics, and depending on which system your truck has, there are a few ANC bypass harnesses available from PAC, iDatalink and LLJ Customs. It&#039;s rare, but I have heard that some people are sensitive to ANC and get headaches after long periods of time in an environment where ANC is utilized.<br /> <br /> Sent from my SM-G981U using Tapatalk</div>
<div class="bbWrapper"><blockquote data-attributes="member: 2576" data-quote="Jimmy07" data-source="post: 149687" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=149687" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-149687">Jimmy07 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Or just use AlfaOBD to disable it, with no need to disconnect anything, and no faults will be stored in the amp. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>There you go, that&#039;s a good tip, that would be the proper way to address the issue instead of disconnecting the microphones or adding a bypass harness.</div>
<div class="bbWrapper">If you have alfa obd, that would definitely be the best option.<br /> <br /> Sent from my SM-G981U using Tapatalk</div>
<div class="bbWrapper"><b>the harness is $15 shipped. I am pretty sure all it does is not make the mic connections. I don&#039;t know what a alphaOBD costs? The harness is cheap enough if disabling the ANC is all you want to do. I ordered a harness.</b></div>
<div class="bbWrapper"><blockquote data-attributes="member: 13414" data-quote="love2build" data-source="post: 149802" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=149802" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-149802">love2build said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Fuse number please? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>It’s F71, but that can only be pulled if you have the base 6 speaker system. Alpine or HK system, the ANC module is the amplifier, and pulling that fuse will kill the whole sound system.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 1989" data-quote="Brutal_HO" data-source="post: 149666" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=149666" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-149666">Brutal_HO said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Doesn&#039;t that depend on which system is installed? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>I should have clarified. This is on an alpine amplified factory system. <br /> <br /> I didn&#039;t notice any different if it helps, due to the speakers having different low/mid/high ranges; I am either going to have to find time to upgrade the speakers, amp(s) with DSP then add ANC bypass back or leave it alone for the time being. <br /> <br /> I feel that replacing the corner dash with infinity ref 3.5&#039;s is too bright even when the fade is pushed back 2-4 notches. I&#039;m not the guy who wants to do competition but I want full adjustable SQ.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 6914" data-quote="JHeat2500" data-source="post: 149685" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=149685" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-149685">JHeat2500 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> You can disable the ANC without total system upgrades. Some people disconnect the mics, and depending on which system your truck has, there are a few ANC bypass harnesses available from PAC, iDatalink and LLJ Customs. It&#039;s rare, but I have heard that some people are sensitive to ANC and get headaches after long periods of time in an environment where ANC is utilized.<br /> <br /> Sent from my SM-G981U using Tapatalk </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> For 19-21 trucks that&#039;s possible, 2022 w UConnect5 has different connectors and Jimmy says they are on a long backorder. I&#039;ve contacted PAC myself and they said &quot;it wouldn&#039;t be any time soon&quot; meaning I would realistically expect a PAC interface in a year or so. <br /> <br /> The other issue is until all the UC5 glitches, updates and other problems are solved I am hesitant on doing anything that could be seen as &quot;an issue causing failure&quot;</div>
<div class="bbWrapper"><blockquote data-attributes="member: 2576" data-quote="Jimmy07" data-source="post: 149687" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=149687" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-149687">Jimmy07 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Or just use AlfaOBD to disable it, with no need to disconnect anything, and no faults will be stored in the amp. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Could you provide simple instruction for ANC disable through AlfaOBD. I didn&#039;t even think about that</div>
<div class="bbWrapper"><blockquote data-attributes="member: 12894" data-quote="Grayson" data-source="post: 149888" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=149888" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-149888">Grayson said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Could you provide simple instruction for ANC disable through AlfaOBD. I didn&#039;t even think about that </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>P/T Chassis Net: ANC Active Noise Cancellation- Disabled</div>
<div class="bbWrapper"><blockquote data-attributes="member: 17080" data-quote="senecagreen" data-source="post: 149536" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=149536" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-149536">senecagreen said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Does this really make much difference with the windows up? Has anyone disabled it? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>I de-pinned the mics this morning. Here is the best video how-to I could find. <div class="bbMediaWrapper" data-media-site-id="youtube" data-media-key="xWIRVODup3o"> <div class="bbMediaWrapper-inner"> <iframe src="https://www.youtube.com/embed/xWIRVODup3o?wmode=opaque" loading="lazy" width="560" height="315" frameborder="0" allowfullscreen="true"></iframe> </div> </div><br /> I do think The active noise control is effective but the random bass sounds are very annoying. First available appointment for the ANC drone and cargo camera blue screen is 2/27…</div>
