ACC / RUN Timeout?
Birton
N. California
If a non-running RAM is left in the ACC / RUN switch position will the truck automatically switch the truck to OFF?
* How long does this take?
* Does locking the truck automatically switch the truck to OFF?
* Does the truck have a low voltage disconnect for continuous drain from USB, Inverters, Aux switches, etc?
TIA
In my 2019, if you leave it on ACC/RUN, it will turn off after 30 minutes. I don't know if there is any separate low voltage disconnect, and I haven't tried locking the truck while it is in ACC mode.
There is a battery saver mode..... why not try to lock your door with the acc on why ask a simple thing to test lol im sitting in my truck just tried it the acc stays on when locking doors with remote like it should
When my truck arrives, I will try it. Just doing research during the incubation period.
Was hoping to find some written documentation.
Is this what you're looking for ?
Key Off Power Delay/Engine Off Power Delay
This setting will keep certain electrical features running after the engine
is turned off. When any door is opened, the electronics will deactivate.
The available settings are “0 sec”, “45 sec”, “5 min”, and “10 min”.
Thank you for sharing. I'll definitely check this setting when my truck arrives!
That's something different.
After you shut off the truck, this setting is used to keep the radio, etc. running until the timer pops or you open a door.
I don't believe the setting can be changed. I did read somewhere though that if you have your foot off the brake and hold the start/stop button for 5 seconds it will override the automatic shutoff timer. I haven't been in a situation to try this yet, but have it stored in my memory bank for when that situation finally does arrive.
The 5 second trick did not work for me. I wish this was a feature AlfaOBD could adjust.
Sent from my Pixel 6 Pro using Tapatalk
Does anyone know if it's possible to go from running to ACC without pressing the button twice?
I like to leave the radio on when I get home amd umload sometimes, and while its a hell of a first world problem I hate that I have to push the button so many times - plus my seat moves.
I'd also like if the dinging would stop, but I suppose there isn't much I can do about that.
