I've got a 2022 CCLB Tradesman 6.7L that came on a set of spare donut tires from the factory. I want to go up to 37's if possible, but I don't want to lift my truck. I might do a leveling kit on the front if I absolutely have to but I've heard that 37's will clear without a lift if the proper rim offset is used. I've been looking around online and it seems that +18 is close to the correct number for a 9" wide rim. If I went with a 10" wide rim would I need to be around +12? If I'm understanding correctly the closer to 0 I get on the offset the further out my tires and wheels will move outboard. And then negative numbers will keep pushing the tires and rim outside the fender coverage so they stick outside of the truck body. SO with all of that said, I would like to order a set of rims and tires, perferably 37's. I would like to know who here is running 37's with little or no lift, what rim offset you're running, do they rub, and if so how badly and how often?
Thanks in advance!
~Necro~
Thanks in advance!
~Necro~
