But I don’t think they open when the intake needs some air. If the shutters are closed, the only air coming into the intake is being pulled through the radiator from the back side. Had they installed an electric fan on the CTD like they did the Hemi, it would have suffocated it. I’m just wondering if the shutters are causing the problem with the air filter and possibly the regenerations also. I wonder if it makes the engine think the filter is more restrictive than it really is. I know they suck in what ever air they need and adjust the fuel to optimize the mixture, but if you add up the square inches in the cracks and gaps, that’s not very much.
Your not having any regen problem in cold weather, with the slats removed, points to it needing cooler air.
