5th gen instrument cluster swap
Hello, first post here on the HD forum. Thought I would share a bit of my experience with this cluster of a cluster swap.
Found a 7" cluster pulled from a Power Wagon on Car-Part for $350. For the price, I jumped on it. Figured I could swap lenses if I cared enough to do so.
Lots of descriptions of the physical swap, I won't go into detail. Not difficult by any means, but not 4th gen easy either.
I was using Alpha OBD on a Samsung tablet and couldn't get the miles to write for anything. Being stubborn, I tried to make it work for way too long. In the past I always used the latest version of android on a phone with Alpha, but had "jumped ship" to apple. Thinking maybe it was an Android issue, I downloaded the windows version the following day and it worked flawlessly. I've seen comments about the mileage not writing correctly, so I was expecting some goofieness. I saw the same thing on the first write, but the issue was pretty clear. Alpha OBD was interpreting "miles" as kilometers (even though the field was described as miles in Alpha OBD). A simple conversion of my target mileage (3626) to km (5835) yielded the correct mileage on my display on the next write.
Alexey was kind enough to share a beta version of his software that he's working on to write hours. I couldn't get it to work. I documented hours so that I can make the change when he gets it working.
The only issue I saw was DTE (distance to empty) seemed to be stuck at 1999. After about 30 miles of driving it started to drop. I've driven about 150 miles so far (starting with a full tank) and it's finally dipped below 200 miles while my fuel gauge is just above half tank. Still a bit higher than I'd expect, buy slowly correcting itself. I'm assuming the calculations are slow to update based off of time and distance averaged data. Anyway, pictures....
Original cluster (only showing for mileage, no one cares to look at these....that's why we swap them):
Powered up fine, mileage as received. Just gave the lens a quick polish with the rotary before install:
Mileage corrected, now people can make fun of me for posing as a power wagon (yes, those are power wagon flares in my profile pic). Coming from a '15 express that posed as a sport, it's all good!
Hey How were you able to get the theme pages ?
Did your OBD programmer update your VIN as well? If i can get the VIN and mileage updated on any used cluster, that will be fine for me.
Question on the 5th gen 3.5 to 7 cluster swap. The last couple I have found and inquired about I have been told will not work as they are year specific. 2022 has been one year I have been told only works in 2022 and 2020 7" needs to be 2020 part # only, any thoughts or confirmation on this.
