Gondul
Prince of Pintops
I have no idea why you care.
Yes RDS makes them...put they are generally not pump fed like transferflow and Titan or they are filler tanks not directly connected to the filler Tube....also gravity fed gasoline tanks are illegal under the DOT code.
Because we are talking about the main tank and not aux tanks.
Any tank can be fitted with a universal low output fuel pump at the top so it can be pumped from the top of the aux tank (per DOT) and into the main tank.
No one (other than you) said anything about a gravity feed.
