Thanks for the insight. By this do you mean to be on a straight path when engaging 4h on a hard surface? Like, if I did it on a straight highway for a mile, is that too long? Not an appropriate place to be ran?
yes, I would say only about a 1/2 mile is more than enough. I think a gravel road or dirt road would be better. I would only do a hard highway surface if thats all you have. I have done mine a few times only 3-5 tenths of a mile.
I would be disappointed if my truck doesn't make up that road.Here is a picture from last week:
Shortly after this was taken, the truck would not. stay straight due to ice under the snow a slush even with. 4wd engaged. I had to back up about 1/4 mile to get turned around.
The 4wd was exercised!
But ill take your work about the ice ...
Is that with the Wildpeaks?
Yeah - I just meant from the looks of it.LOL, I'm not disappointed at all. 3 inches of slush and snow over ice....and whereI stopped was up the road a ways with more snow and quite a bit steeper. Kind of hard to make a statement like that when you weren't there.
As far as the Wildpeaks go, the jury is out on snow performance. They did well up to the point that ice and increasing grade became a factor. We'll see how they do this winter. But, for being as aggressive as they are, they are still very quiet on the road, grip on gravel seems good, and wet pavement performance is better than the stock tires. So far I am pleased.
Beg to differ. I agree that it's not such a big deal for the current transfer cases. The issue is with the front axle disconnect mechanism. Whether vacuum or solenoid operated, these gizmos should be exercised regularly, especially if you hang your hat in a region of North America that is accustomed to vicious winters.Just for the record, there’s definitely no need to cycle a 4wd system on a regular basis. The internals of the transfer case (with the exception of the output shaft) are turning anytime you drive anywhere, and the fluid is being circulated by the pump as well.
