I’m going to post this in several threads because I’m so happy that I’m finally done, complete, no mas!!! Based on everyone’s experiences shared here I pulled the trigger and bought the Air Lift Loadlifter 5000 Ultimate Plus. The stainless sounded like a good idea based on others (Brutal’s) recommendations. After a few days of over thinking and watching YouTube I also bought the 74000-2nd gen compressor with the EZ mount. I was scheduled to have the guys at Trick Trucks in Chantilly VA install for me. Unfortunately I was exposed to 2 different people with COVID and subsequently quarantined so I had to cancel. I got tested and waited for my test results and all good, the wife and I were both negative.
With time on my hands, the idle mind/devils workshop theory took over and I searched the ends of the internet on the subject and through the magic of You Tube, it seemed easy enough...I would soon come to appreciate working on a truck on a lift versus underneath, on a creeper, on your back makes a big difference. Amazingly enough I still fit under the truck without needing additional clearance of jack stands but... if I’m being honest, I’m about one donut away from not being able to !
The only real setback I had is the Ultimate Plus comes with braided stainless air lines that require additional fittings that didn’t come with my kit. I took time to find quality products, I eventually got the correct elbows that mount in the bag and I was in business. I took my time and followed the instructions ... this time...
I opted for the setup where compressor lines tie into a T union which gives me the ability to also manually fill as a redundancy if the compressor fails. I ran the manual line schraeder valves to the license plate bolt for easy access. The wireless remote pairs with the manifold when you first put the main fuse in. The manual says you have 5 minutes but it didn‘t take on the first go. I pulled the fuse and repeated the process and synced on the second go around. So far everything is working as it should without errors. No leaks so far, let’s see how it does overnight.
We’re going to tow the new TT this weekend I’ll post how it went when I’m done.
This video was the most helpful setting the compressor up.
