2500 vs 3500 ride
My buddy’s 2018 2500 CCSB 6.7 easily towed a 14k gooseneck loaded with 2 Jeeps between TX to CO without issue. Also 4 guys in the cab. Over payload? Of course. Over GAWR or GCWR? Nope. Stable as heck and no problems. He added aftermarket airbags as he thought it would squat but it handled it so well I think he only had maybe 10-15 psi in the bags. He started at 40 psi he but said it was stiff as hell so he dropped it.
If you’re concerned at all about numbers and your budget allows, get the 3500 and the HO so you’ve got the best of the best. It would be overkill for the 8k trailer but you’ll not have a worry, can step up to a lot more trailer later and those are worth a lot to many people. Even less worry would be add DRW as well and you can go really big.
With the 3500, need to be mindful of the 26,001 GCWR CDL limit and check your state’s towing weight license requirements. That’s partially what kept me out of a 3500 MC at 12,300 GVWR. If I used it to tow my buddy’s 14k gooseneck in TX I would need a non commercial CDL license as the GCWR would be 26,300 thus over the 26,001 limit.
@Monoman Let us know what you ultimately order/buy.
The bags are where the leafs go so it makes it very stable the only reason i am buying bags is the windy roads with the water tote you can feel it a bit side to side but not bad enough where i had to slow down for turns
Makes sense the bags will help moreso due to their location than increasing spring rate.
Other than than the rear springs, the 2014-later 2500 and 3500 SRW trucks are identical down to the last bolt. Same frame, 50KSI steel, same axles, axle ratings, same tires, no physical difference. The ONLY difference is the US Govt DOT GVWR ratings, which are mostly arbitrary depending on how the OEM markets the truck.
The coil springs in a RAM 2500 have a similar spring load to a leaf spring SRW RAM 3500. Sag with trailer loads are similar if not favoring the 2500. However, the spring rate on a 2500 is softer, hence the better ride and lower GVWR rating to fit under the arbitrary DOT 10,000lb GVWR limit.
Great points and article.
The same was true for the early 3rd gen Cummins. The rear spring pack was different. but evey thing else was the same. Good article. They did talk about the springs being inboard on the 2500, which has been known for being one of the reasons for the squiggle. Not sure about the 16,200 Max Tow numbers they cited for a 2500 Cummins though. Ram has the 2019 Cummins 4x4 CC short bed MTW at 19,350 with the GCWR at 27,000. Even maxed out at full payload (truck + payload =10,000) you would have at 17,000 left for GCWR. Not that I would care to tow that. Maybe the 2021s are less?
