H3LZSN1P3R
You're doing it wrong
With a manual trans sure, not with an automaticI'm just going to point out that while you may not "need 4wd", you will find 4-lo to be super helpful when spotting your trailer
Unfortunately it is too late, I am into this one for $1200.00.I’d buy a different hitch if they are that fragile.
Gear reduction is gear reduction, I've used 4-lo many times backing a trailer in a tight spot with an automatic.With a manual trans sure, not with an automatic
I am well aware of the gear reduction but unless in slick conditions or terrible inclines there is still not much need for 4Lo if you have good throttle control even with tight spots. Causing binding in the drive train with 4LO is not my go too method of backing in a trailer now if you had something like the BD 2wd LO kit then that would be good.Gear reduction is gear reduction, I've used 4-lo many times backing a trailer in a tight spot with an automatic.
Towing on ice is not so bad lol but yea unless you have a 1/2 ton or way out of wack trailer a WDH is not worth itWait is this a WDH thread or a thread about using 4Lo with a trailer?
WDH - belongs in the garbage
4Lo off pavement - anytime you want
4Lo on pavement - only straight backing up*
*If you’re towing on ice may the towing gods be with you
I’ve never taken my bars off on the Equalizer hitch I have either.WD has its place for sure. Some of you may have the perfect setup that doesn’t require it. Others don’t or they are asking a bit much of their coil sprung big trucks. Most WD setups, with friction bars of course have built in sway control. Less porpoising is another benefit some experience.
Now taking the bars off for any backing up…..yeah no. I jackknifed and parked that camper in some places and yes they made noise but they always worked and nothing broke.
Sent from me
I’ve had mine on 3 different trucks and each one has to be set up a little differently but easy to do with an impact wrench. Used new bolts and nuts each time.That’s what I ran. I fitted that to a Bulletproof hitch and their WD adapter. Tailgate opened with out hitting or turning the jack. It was a great setup.
Sent from me
Not really expensive like some and easy to configure.Equal-I-Zer is not one of the brands that requires disconnecting the bars for reverse. They also rate the head the same with or without the bars attached.
It's a great WDH.
I am using Weigh Safe WDH. When it talked to them they were very adamant about not backing up with the spring bars connected. I asked “what if I need to back up to maneuver into a gas station pump” and they said I would have to get out and disconnect the spring bars. Not doing so could damage the hitch.
If I ever get around to getting my aux switches installed I’m putting that on next. Every time you mention it I wish I had it.Used 4-Lo on pavement to back my trailer in a tight spot last week.
Well, technically it was 2-Lo.![]()
