Riddick
Well, I wish I had some great news here but unfortunately I do not. I purchased a 22 tuning package from Calibrated Power back in June. Literally 3 days later I broke my collarbone so I have been patiently waiting to heal so I could install everything. The package from CP comes with everything you need including HP Tuners MPVI3, tuning credits, gateway module bypass cable, and a brand new unlocked Cummins ECU.
The first step of this process is to perform a read on your stock 22 ECU. Everything here went very smooth, CP has detailed instructions on what kind of logs they want. I sent off the logs and CP verified everything looked good and I was ready to swap in the new ECM. This was not very difficult but you do need to take your time when doing it. From start to finish I prolly spent 2 hours total and I went through the wheel well so I had to pull fender liner and wheel off for access. You can access from the top of engine bay but it provides less space but will be faster for sure. Once the OEM ECU is removed you have to remove your charge pipe off the power valve and snake it through the top.
Once the new ECM is installed you have to perform another set of reads and email them off. I sent them over the weekend and had my new files ready to go in today. They give you 2 files to load, the first one went in without a hitch and im thinking this is gonna be easy...... WRONG. The second file was in the process of loading and when it reaches 100% you have to turn the truck off for 10 seconds and then back to on. When I did this I received an invalid checksum error and a Failed message. I was pretty bummed at this point but made a few calls to CP and we tried loading the file a few more times with no luck, even tried loading the first file that loaded fine earlier and that failed too.
CP has been great to work with so far and I don't blame them for what's going on. I am confident its an HP Tuners issue and not related to CP. I noticed Kory Willis from PPEI recently made a facebook post stating HP Tuners was bricking ECMs and HP Tuners had him remove their products from his website until they sort it out. Pretty sure my ECM is toast and I will more than likely swap back in the original one this week so I can have my truck back up and running.
CP is submitting a trouble ticket tomorrow and we will see what happens. I am not giving up on tuning the truck and I will keep updating this thread as I receive new info. I know there are a few members on here wanting to tune their 22 and 23 and hopefully this thread will help them.
