DeadEndCustoms
I did a search and found the same problem similarly described, but the solution isn't the real fix as far as I'm concerned: Passive entry doesn't unlock rear driver side door unless set on All Doors, but Passenger will unlock All Doors if set on Driver Only?
I asked this question on another forum and they said their 1500 does the same. There probably isn't a fix and this is probably normal, just want to confirm because it seems ridiculous.
Problem
- With the setting '1st Press of Key Fob Opens Driver Only'
* When I grab the driver Driver Front door handle, the passive entry unlocks: Driver Front Only
* When I grab the Passenger Front door handle, the Passive Entry unlocks: ALL DOORS
- With the setting '1st Press of Key Fob Opens All Doors'
* When I grab either Driver Front or Passenger Front, the passive entry unlocks: ALL DOORS
So I like the KEY FOB only opening the Driver Front with one press, but it's ridiculous that in this setting, the Passenger Front can open all doors when the Driver Front won't (via Passive Entry). I mean the whole point is for safety, so I may be missing something entirely here. I'm not necessarily looking for a solution, but I'd like to know if other Ram's have the same issue and avoid the Dealer again..
Dealer: So a couple of weeks ago I took it in for some warranty work (Mobile Connectivity Failed on UConnect, requiring new UConnect components), and showed them this issue. Once the UConnect components were replaced, they could not replicate the issue and kept it 2 additional days to try and get the issue to repeat. Once I got it home and adjusted all the settings back from default, I realized they couldnt replicate it because the default was set to open ALL DOORS so they never saw the problem again. I called back today and explained what it's doing and now I have an appointment. If this is normal, I'd like to not waste my time with an appointment and getting rides...
TIA!
Problem
TIA!
