That’s where you see manufacturers skimp- not just ram but everyone- saving .12 cents on a cheaper u joint that causes frustration down the road.
I was bored last night and read something about the new ZF trans. Supposedly part of the fuel economy “savings” is a feature called “start-stop”. It basically shifts the trans from drive to neutral every time vehicle comes to a complete stop. Sounds like the engine start stop the industry went to on everything to meet Obama’s CAFE standards. I find this the most annoying feature on new cars and it turned a $200 starter into a $1000 starter with extra wear and tear.
The integration of a similar feature in the transmission will likely cause addition wear on the transmission and just complicates it which likely will increase cost to save a little fuel. I know .gov has caused this problem and the manufacturers have their hands forced, but it’s still frustrating.
lol, Ram is not using cheap or inferior u-joints… they simply have size constraints. They are huge, just not enough for 1075 ft/lbs and a 3-4:1 1st gear.
I have no doubt every single vehicle on the road has some type of torque management to some degree, hell, my wife’s Honda Pilot dead pedals in a few situations and it’s infuriating. Some bit of torque management might be needed but when it’s so much so you don’t get the full 1,075 ft lbs what’s the point of chasing these silly numbers? Most folks don’t buy these trucks to stop light race or race up the Ike, just say’n. As to the rest of the driveline, the trans is the weak link. I’ve seen way too many examples of highly modified diesels on huge tire doing stupid things like boosted 4 wheel drive launches on stock axles and tcases, those components will take a good bit of power.
I like torque management, to a point. It keeps components alive and lets us have more power when we need it, such as the upper gears where we lose torque multiplication. 1075 isn’t needed in 1-3rd gear, but it’s really nice in 4-6.
Yes the trans is the current weak link, but if you build a trans to hold full power in lower gears and hook up to 25K lbs you will find that the rest of the drivetrain is undersized.
