Look at the graph I've pasted few pages ago. Temps are normally around 600F - may be too low.SCR has not ever needed or used in-cylinder dosing, why would they start now? Exhaust temps from driving are sufficient to let the SCR reduce NOx with DEF.
Adding in-cylinder dosing for the SCR, when it’s closer to the engine, would be the opposite of what they are trying to accomplish with the 7th injector. That’s the point.
7-th injector is for DPF's DOC. First DOC afaik does not have own injector so there is no other way to heat it up.
You can see such event on the graph mentioned.
EGT2 and EGT3 went up having EGT1 not much elevated. This all with DPF temperatures being lower.
