Buckrub
LOL. If arguing over semantics is our biggest issue, we're fine.
But my answer would be.......just because someone wrote a manual and gave a name to an actual phenomenon, that doesn't make that guy's name the 'bestest and onliest' one. Does anyone use CCC or Cargo Carrying Capacity? Yes, everyone I know, and I've been around countless dozens of experienced towers of 5th wheels. A few use "Payload" but they all know it means the same thing, and no one cares which one is used. I assure you it is NOT to try and 'sound smart'. I couldn't do that if I tried, because I don't know diddley squat about trucks. I know a little about towing. So I'm not smart and I don't try to sound smart. I just use both terms to mean the capacity of the truck in all aspects (axles, suspension, etc etc etc) to carry my 5th wheel hitch and all my crap.
Erik, my answer to you is that countless people have pulled a trailer like that one with trucks like yours, for miles and all over hilly America. Many of them don't care one whit about their specs. Others, like me, got just as worried as you are about it before we bought the 5th wheel. In my case, I went and bought a dually before I even had the 5th wheel, simply because I got nervous exactly like you are doing, and I talked to lots of people, and that led me to a Dually. Even that was barely enough IMHO. I never pulled my 5th wheel all over America and thought I had too much truck.
PAYLOAD is diminished by such things as 4WD, hitches etc. I have not seen a single normal 5th wheel setup where the PAYLOAD capacity number that is below the door jamb number is below the actual weight when using a SRW truck. But there may be one, there may be lots, I've just not seen one. Heck many people tow big 5th wheels with 3/4 tons!
My suggestion, worth nothing, is for you to get what you want and then go weigh at a CAT scale (with the app you don't even have to get out of the vehicle) twice, loaded and unloaded, and calculate your situation exactly. But being a few pounds under or over has never stopped anyone I know from towing.
The ONE thing you should understand, and it appears that you do, is that a 5th wheel has "pin weight" that bumper pull campers do not have, and that pin weight is added to the total cargo capacity. My BD5D hitch is very heavy and eats into my payload a lot. That and my overly heavy pin weight don't leave me a lot of room, but I'm not over. Things that help are air bags and bigger wheels/tires on 5th wheel, better H rated American made tires and wheels on camper, independent suspension on camper, etc. Point is, there are things you can do if you are way, way overweight after you buy, but you are doing right thing by considering it first. Trust me, not many 5th wheel buyers even try. RV Salesmen all have the same line "Yep, your 1/2 ton truck will pull anything on this lot".........when it won/t.
Best of luck
Best of luck
