cc1999
I ordered my suspension from CJC Off-Road for the new 2023 Ram 2500 LTD with factory air ride yesterday.
I will report back with pics and review once installed.
Goals were minimal lift as possible.
Smoothest ride as possible
Still maintain 100% towing capacity.
Improve the steering stability as much as possible.
The 1"Thuren soft coils looked to be the best bet to improve the ride smoothness given my truck as factory rear air and that limits my options of what I can run with it. Carli has pin-top king setup for trucks with factory air but crazy expensive and more lift then would really work well for me. But Carli does seem to have the best steering stabalizer kit on the market with their new true dual with the upper and lower kit.
CARLI SUSPENSION 2014+ RAM 2500/3500 TRUE DUAL STEERING STABILIZER SYSTEM
Would love to hear owner feedback from anyone running a similar setup.
Here is exactly what I have ordered for my new 2023 Ram 2500.
Shopping cart
Scroll for more items
Cost summary
Here is my truck 100% stock the day I got it.
Later that same day with its custom wheels and tires installed.
18x9 +20 offset with 295/70R18 Tires.
Here is the 23 with his older brother.
My 2015 2500 also has (Edit) the same Thuren soft coil setup 1" front and stock height rear mid-rate coils with King shocks and bunch of other Thuren stuff.
That 2015 rides awesome. But the 2015 with its suspension setup it is just not as good at towing heavy anymore.
Wanting to keep the new truck fully capable of max towing with max stability.
New truck as it sets today with its windows tinted.
Awaiting its rack and toolbox to be finished and all installed hopefully next week and the week after the new suspension should be getting installed.
If you're looking for the best steering stabilizer setup for a 2014+ Ram 2500 or 3500 truck, look no further. While most brands use "dual" stabilizers with two shocks on the tie rod for looks, Carli pursued a different route with a true dual opposing stabilizer system that uses one stabilizer on the tie rod and one on the drag link. Simply put, there is no better stabilizer setup on the market for 2014+ Ram trucks. Carli uses proprietary stabilizers with a custom valving profile and small shaft diameter to offer maximum damping and impact resistance without negatively impacting steering feel. Their fully-rebuildable construction boasts a Stainless Steel body with Machined Billet Aluminum Rod ends housing precision 1/2” Spherical Bearings topped off with a hardened Black Nitride Shaft. Each stabilizer’s nitrogen chamber is adjustable from 70psi to 200psi allowing customers to correct for radial tire-pull in various configurations. If no pull exists, the Stabilizer can be set from 70psi to 100psi as this neutral range will pressurize the oil for proper function without biasing correcting in either direction. Please note that the Carli high mount stabilizers included with this kit ONLY work with factory Mopar linkage, and no aftermarket options!
Shopping cart
| Product image | Description | Quantity | Price |
1 | Thuren Fabrication 2014+ Ram 2500/3500 Active Rate Sway BarBillet End Links | 1 | $660.00 |
1 | Carli Suspension 2014+ Ram 2500/3500 True Dual Steering Stabilizer System2019+ | 1 | $885.00 |
2 | Shock Boots for 2.0 and 2.5 ShocksSmall (2.0 shocks) | 2 | $50.00 |
1 | THUREN FOX IFP LEVELING KIT RAM 2500/3500 (2014-Current)2500 / 1" Diesel / Add Thuren Fox 2.0 for Stock Coils | 1 | $1,540.00 |
Cost summary
| Description | Price |
| Subtotal | $3,135.00 |
| Shipping | Free |
| Total | USD $3,135.00 |
