2022 tow mode camera wiring question need to locate correct cable
johnptc
i recently bought the trailer camera kit / tow mode camera kit. 68527599AA, my truck is pre-wired for the tow mode camera and digital mirror is already there. The connector is just left of the license plate on rear bumper.
the very long cable that it comes with the kit has a small plug on one end which fits the camera directly.
the other end as shown is a large coax fitting ( see photo). this does not fit the oem camera connector just to the left of the license plate in the rear.
i am looking either cable with male and female small size plugs (see photo) or a cable with the same.
many thanks
Please include a pic of the bumper side fitting. That’s the correct cable (I installed that kit with the long cable that came with it on my 2022 2500). I was advised to use some dialectic grease around the blue o-rings and it made the connection MUCH smoother.
I think you should check again. Looks right to me and like every connector that's been shown in the forums. A source for the bumper end cable has yet to turn up available anywhere.
i think you solved my issue. i had to have the rear bumber replaced. my guess is that the correct fitting was install as oem. i think it the connector as such did not get re installed. my guess is that if i buy a replacement bumper connector the small cable on the truck will plug right in. then the supplied cable should be a match !!!!!!!!!!!
million thanks, i will check if i am not missing a part :)
i think you are correct.... i just need the part number of the bumper connector fitting and i should be good to go.......... assuming it will accept the small cable on the other side :)
I need this blue connector piece, any idea the part number or where to find? Cable disconnected during a sharp turn and I lost it
Pretty sure he's looking for the tnc adapter/connector.
Sent from my work avoidance device using Tapatalk
I found this post and I am looking for the same connector plug. Would you have the part number? Went to the dealer with no luck my trailer camera keeps disconnection and I am sure it is this plug. Thanks in advance for any help!
David
David
I’m looking for the same but would settle for the just the fitting without the overmolded housing. Anyone have insight to what is required?
for what it is worth
Bingfu Fakra Z Female to Male Vehicle Antenna Extension Cable 3m 10 feet for Car Stereo Android Head Unit GPS Navigation FM AM Radio Sirius XM Satellite Radio 4G LTE TEL Telematics Bluetooth Module from amazon will fit the camera and the truck wiring but not the bumper fitting which is plugged into the wiring harness with this type of plug
If anyone is still looking for the cable to bumper plug after long arduous nights and sleepless days i found it part number is
68532403AA​
