2022 Cummins Front Wheel Bearing failure in 3 months???
Please lube your hubs fellas. They'll literally last forever unless defective like the OP's. Pull the ABS sensor and force grease in there when nearly new and then every 75-100k. You can feel the bearings loading up with fresh lube while spinning when adding grease.
Force grease in where? Pictures or a diagram would be helpful. I'm not familiar with this newer axle, are the bearings and hub a modular system with a hub like on an independent front suspension. Or is at like the older school axle with tapered roller bearings.
