That remains unclear.Sooo we think they are continuing to build trucks with the bad ring?
The tracking sheet is up and running. Please share. If you are on the list, please make sure your data is correct. If not, I can update. Also, if someone is not on there and would like to contribute I can add. Public has viewing and commenting rights only. Thanks!
Link to the sheet:
2022-2023 Ram / Aisin Transmission Failures Tracking
docs.google.com
Will do!Add me to the list 22 ram 3500 build date 11-22 took delivery 2-4-23 transmission failed 3-3-23 miles at failure were 1542.
Lost 1-4 gears had reverse and I guess 5th gear after a hard jerk. We were towing at the time and came to almost a stop on the interstate when we felt a hard bump and dash display 4x4 not available at this time followed by a check engine light. Dealer has confirmed K1 clutch drum issue and we are waiting on parts kit with an expected ETA of 2 weeks on parts. Dealer is requesting a new transmission but Ram is saying they are not available at this time and they are under an engineering review until mid April.
I’ll go by there today or in the morning and get it myself, the truck is sitting outside but I do know it was manufactured in USA I remember seeing that on the tag. Thanks for taking time to make the sheet and for the add on.Will do!
Sorry it happened to you.
If possible could you see if the dealer will read you the serial number off the side of the failed transmission case also? I’ve been trying to gather those as well. I really appreciate all the information. I will get you on the sheet momentarily.
Thanks let me know! The truck is built in Saltillo Mexico but the Aisin is built in USA.
The transmission serial tag will look like this:
Yessir, my transmission serial is 1I-1866mbarber84... is that ID tag off your truck?
I thought that might work but there is a “3” for a first digit in one of the serial numbers reported to me. That wouldn’t work for a 2022 truck built in October of 2022.Any guess as to what the serial number code indicates?
Maybe something like:
1st digit = year
2nd digit = month
last four = sequence number for that month
The trucks are at the dealer, can this information be pulled out with the vin #'ssidielin1989...
Not trying to be disrespectful, but if you expect us to believe that you have three broken trucks, you will need to provide additional info.
-please introduce yourself in the new members sub forum https://hdrams.com/forum/index.php?forums/new-member-introductions.5/
-what is the build dates and mileage for each truck that failed on you?
-please provide the transmission serial number for each.
I have it in good authority that the issue started at Aisin. It wasn’t an assembly error but rather a batch of snap rings that were out of spec. Somehow made it past quality control. They fail internally and fall out of position on the K1 drum. When this happens you lose 1-4 gears instantly.My 2022 ram Laramie, 3500 HO/Aisin transmission failed at 6000 miles. Took delivery last September. My service manager says an employee was installing a part wrong and that’s why they are failing?? Truck has been there since 1 March I’m third in line waiting on parts. There are 14 truck sitting there now . Same as the rest of the issues, 4 x 4 not available, goes into neutral stalled in the middle of I 10 in Houston. Had a 36 foot toy hauler attached and what a mess. I’m told they are taking parts out of existing transmissions to make repair kits. Dealer said they’ve only had to replace one complete unit so far.
