2022 5500 backup camera
IFlyEm
So I'm trying to add a backup camera to my 5500. I have a camera but it seems I need a different one or I need an adapter for the digital camera plug in the harness.
Anyone have a part number for either?
Thanks!!
I have the trailer 360 kit but no backup camera. I have the wire harness for it on the truck. Just need to figure out the adapter or camera with the proper plug.
I dont think you have the proper camera there i would bet you need the camera with the fakra connection (analog) not the digital one. Where did you get that camera?
@Jimmy07 can you help this guy find what he needs?
That's the only camera I could find that was for a 2022 5500. But you can't find really anything reliable online. Does the 3500 have a backup camera with the fakra connection? Is that the wrong camera connection totally?
I dont have any actual info on it but the guy i tagged knows all about these systems he is out go to guy for these questions
My 2022 5500 was ordered with the backup camera. The part numbers were:
Rear view digital camera kit 68544395AA, with cable 68544396AA and camera 68442521AA
See this post:
See this post:
I’m not sure if it matters but do you have the surround view?
Yes, but the rearview is not integrated into the surround view, only the front and side mirror cameras are.
Perfect. Then we have the same setup.
I can't find the cable 68544396AA anywhere.
I wonder if a generic Fakra cable would work.
Ok so I got a Fakra cable and connected one of my trailer cameras to make sure it worked. Seemed to work pretty well. A couple things:
- It only showed the narrow field view option. The wide view is not selectable. Is this normal or is it camera specific?
- I activated guidelines with Alfa but it's not showing up as an option in the system settings nor is it showing any lines on the camera screen.
And ideas? Definitely better than nothing but would like to get everything out of it I can.
