2021 mega cab all weather mats for back seat?
I would like to find something that will protect this area of the carpet. My boot rubs up against it and I can see it wearing as a result.
You are not going to find anything that comes up that high because of the danger it could flop over and interfere with the pedal. Might be able to come up with something yourself though?
Ram should integrate a wear pad into the carpeting. I have seen such a feature on cars. I might try to fabricate something like this.
Mine is even worse because the fit isn't right and it protrudes into the pedal space. I asked the dealer to fix it when they did the A/C TSB and they actually made it worse.
FWIW, They also put two cuts in the leather 4x4 switch bezel surround and messed up the center console top screws by using a power tool on them and deforming the plastic enough for one insert to pull out. :mad: Now the center console stack tray holes are deformed permanently due to heat exposure while they were overtightened. I also found one white panel clip all the way in the back floor area and have no clue where that's missing from.
So the regular crew cab rear liners will work with the mega cab? I just want to be sure before I order the Husky x-act liners.
That would get me kicked out of the service dept real quick. Ugh...
No, the rear is different. Only the front is the same.
Thanks, I went back and realized that I misread and the person I was thinking of when I asked had the Weathertech liners. Worst case, I will just get those for the rear next winter if needed I guess.
Ok, so the way I read this, nothing about the 2021 Ram 3500 Mega cab interior has changed from 2020. So these 2020 floor mats should fit my 2021 Mega cab 3500. Can anyone confirm?
