Hello everybody, long time lurker first time poster. 2021 2500 Tradesman.
I’m at wits end with my tailgate and am looking for any other ideas before taking it to the dealer. The tailgate had the recall completed and was working fine for ~1 year or so before somewhat overnight, nothing would work to get it open. With an aviation maintenance background I started with the fuses (checked F14 and F30 based off other threads, both checked good), traced the wire bundle back, and after not seeing any obvious issues, got to the tailgate. I removed the tailgate, disassembled the wiring harness from the tailgate and checked the harness as well as all connections for scoring/corrosion or any cuts in the harness. All fit snugly and seemed to be fine. Interestingly enough the rear view camera, which shares the wiring bundle until splitting, works perfectly…which leads me to three possible culprits:
1. There’s another fuse I’m not aware of…
2. Both tailgate latch mechanisms failed simultaneously. Unlikely but an option.
3. The pressure switch in the handle (my vehicle doesn’t have the key fob opener) failed.
My gut tells me it’s number 3, but before I start down this eternal rabbit hole, was curious if there are any other avenues I could check.
Appreciate any help or recommendations!
