Trophy Truck
Hello Fellow 2020 Ram Diesel 2500 owners, I am having trouble with my wiring from my truck to my 2019 newer Lance truck camper. Nothing wrong with camper as I took it off a previous working vehicle. I keep blowing fuse #29, the 20 amp cartridge fuse (Trailer tow Park) whatever that is? I am no beginner at this... I tapped my camper wires right behind the 7 way at the Ram truck bumper and tested voltage and double checked the lights. I start the truck everything checks out ... Left turn, Right turn, lights, Reverse light, good Ground, after about 5 to 10 minutes or so the camper lights go out and thus the fuse is blown, no issues with the truck lights. I called the Dealer previously and they referred me to a accessory shop, so I called them and they use a junction connector that piggybacks at the 7 way, then you connect the camper wires to it. Basically the same principal as I've accomplished. By the way those 20 amp cartridge fuses at the auto store are $5.00 each. Does anyone have any input. Thanks
