It's also robust enough to use comm.ai, an aftermarket self driving solution.
OK, you're really scaring me now. I'm not fond of the whole self driving idea in the first place, but adding AI into the mix along with heavy duty trucks makes it sound even worse. YIKES!!!It's also robust enough to use comm.ai, an aftermarket self driving solution.
So I'm still confused on the "steering" system, what's the difference between "Lane Keep Assist" and "Adaptive Steering", and what does everyone think of them?
Thanks for clearing that up @Brutal_HO, are both features available on most or all trims starting in 2019?Lane Keep Assist, which you can adjust and even disable if desired, is intended to "assist" by applying torque to the steering if you drift towards a lane marker. It's referred to as the "Lane Departure Warning System."
Adaptive Steering changes the steering gear ratio during slow speed driving. Less steering wheel input for faster turning. It's a beautiful thing.
Thanks for that ShadowJ, so not sure when the switch from UC3 to UC4 was but that might be a factor?
