12 inch Uconnect 5 part list help
If your original radio is an 8.4 non-nav, you need an adapter harness for that black HVAC connector (like @Wheelz identified above).
You also need the LVDS cable that links the screen to the radio. There is no separate part number for that for the 2022 UC5 radios, and a UC4 lvds cable won’t work, it has to be custom made. I can build both of those for you if you need them.
Jimmy07 I bought a used 2019 bighorn that had the 5” screen original, previous owner put in a 8.4 screen but it was out of a 2016 Durango so the backup camera never worked. I went and bought a 12” screen for a good deal I believe out of a 22 2500 Lamar or .. is there a way to install this one? I have the dash pulled and it’s not looking good for me. Do you build a harness to adapt ? Thank you!
@Jimmy07 I bought a used 2019 bighorn that had the 5” screen original, previous owner put in a 8.4 screen but it was out of a 2016 Durango so the backup camera never worked. I went and bought a 12” screen for a good deal I believe out of a 22 2500 Lamar or .. is there a way to install this one? I have the dash pulled and it’s not looking good for me. Do you build a harness to adapt ? Thank you
Can you give a price ship to 32909 wiring need to do the swap I have a 5 u connect now I purchased the 12 inch width module
Does anyone know if the 12.1 bezel from a 1500 will work on the 2500 trucks? I have a Bighorn with the 8.4 and was thinking about changing to the 12.1” screen, but the only bezel I can find that matches my current trim is from a 1500.
can anyone tell me if this module will work for the uconnect 5 swap
Jimmy07
Hey Jimmy07, I currently have the 8.4" uc5 non nav ubd radio in my truck and I purchased the 12" ubq uc5 radio to put into mine. I have the new uconnect 5 receiver coming but I need the adapter wires that make the trucks original wiring work with the new radio and receiver. Can you please make those for me? I will pay whatever you want. I can't find anybody who makes or is willing to make them for me. Please get back to me when you can. I know you have a lot bigger things to deal with but I'm struggling trying to find this stuff. Hope to hear from you!
Anyone know what screws are uesd to attach the twelve inch screen to the bezel so I can pick some up or order them from mopar if I have too
If you’re still looking for parts numbers I have some. I just upgraded my 8.4 non nav 4c to the 12” uconnect 5 system. I’m still stoked over it every time I get in my truck!
Module # 68507350AB - works with 8.4 or 12”
12” screen (center stack) # 68526609AB
This center stack is for the diesel with traction control and hazard button at the top without lane assist.
Bezel for the 12” screen # 6UV473X9AB
This one is silver and black with the carbon fiber at the top by the 12v port.
You’ll also need a custom harness that I believe Jimmy07 can help you out with.
You’ll also need Alfa obd to program it
If you look hard enough you’ll find different part numbers for different interior options.
Fist thing I did after hook up was to update it from 23.13 to 26.15
Hope this helps.
How do you update the radio to the new number?
I def need those cables made I have a 2022 ram 2500 8.4 non nav....IMG_0310.jpeg
anyone wouldn't happen to know the part numbers to get auto climate when upgrading? Im sure it will need a special cable made(lol)....
anyone have issues with traction control button not working? Im 2022 ram 2500 8.4 non nav uconnect 5-12 uconnect 5... attached is what I changed to see if it works but no go @Jimmy07
anyone having issues with traction control not working enable cabin Net: DCSD DISPLAY SCREEN MODULE ENABLED SOLVED MY ISSUES
I def need those cables made I have a 2022 ram 2500 8.4 non nav....View attachment 93095
Did you have wireless CarPlay with your 8.4? I’m considering upgrading to the 12 just trying to make sure I’m tracking all the correct parts required. I have a 22 2500 with 8.4 non nav & wireless CarPlay. Sounds like I need the module, 12” uc5, bezel, and a harness from Jimmy.
