2021 RAM 3500 Tradesman | AEV Prospector | FWC Grandby
I selected the Luverne Grip Step 7" x 98" aluminum wheel-to-wheel running boards after a thorough search for options suited to a regular cab with long bed. Full-length boards proved scarce - most covered only the cab area - while I required frame-mounted brackets exclusively, avoiding any rocker panel attachment. I also prioritized a flat platform with expanded metal tread surface for superior traction and debris shedding in demanding environments. These Luverne steps uniquely met all criteria, making them the clear choice for my build.
The 7-inch-wide stepping surface ensures safe, comfortable access and egress. The open expanded metal treads effectively shed dirt, snow, and debris from boots, and the powder-coated aluminum construction delivers strength, low weight, and complete rust resistance.
As installation neared completion, I briefly considered omitting the end caps. Upon reflection, their smooth, rounded profile eliminates sharp edges and neatly conceals what would otherwise be an exposed, unfinished end - enhancing both safety and aesthetics.
Two standout features deserve mention. First, the expanded metal tread pattern matches that of my camper entry step stand, creating uniform footing and boosting overall safety. Second, the running boards mount at precisely the same height as the top step of my stand. This eliminates the need to haul the stand when securing or releasing the front four roof latches on my Four Wheel Camper - a small but meaningful efficiency gain. In freezing conditions (teens or twenties), manipulating cold metal saps hand warmth quickly, and gloves compromise the dexterity needed for those stubborn latches - making this integration a genuine time- and comfort-saver.
This is the front mounting bracket on the driver's side. The powder-coated brackets employ stainless steel fasteners and exhibit high-quality fabrication.
The instructions were thorough and illustrated, but contained a notable gap: body mount bolts are to be discarded without reuse, yet no guidance addresses the substantial factory washers (~4" OD). Luverne tech support offered no explanation for their function and insisted on non-reuse per the manual. Observing the kit's bolts were 10 mm longer each, I applied basic load-distribution logic: the washers must remain to spread force evenly over the rubber body bushings. This critical detail appears to have been omitted during the transition from design to documentation.
Here is the rear cab bracket on the driver's side. On a crew cab, an additional body mount and bracket would appear between front and rear; for my standard cab, only two per side are required. Vertical adjustment capability here is a smart, practical touch.
Close inspection of the load reaction studs reveals how they preload the brackets against the frame, channeling step loads directly into the chassis rails. This is a solidly engineered approach with broad adjustment capability that impressed me.
The rearmost bracket attaches to the side of the front eye bracket for the rear leaf spring on my one-ton truck. It uses a 30 mm head bolt torqued to 350 ft-lbs (my son handled the final torque). Horizontal adjustment is available if needed. In summary, the frame brackets reflect thoughtful, heavy-duty engineering with practical adjustability.
Tonight I camp in the Croatan National Forest where it's been in the 20s the past few nights, the crisp air sharpening every rustle in the underbrush. Named for the Croatoan tribe who once called this region home, the forest guards the echoes of the enigmatic Lost Colony - those 115 English souls who disappeared from Roanoke Island in the late 1580s, leaving behind a single carved word: "CROATOAN." Many believe they blended into the local Native communities hereabouts, their fate a mystery that still draws explorers like me to these shadowy pocosins and tidal edges, searching for traces in the silence.
As I continue my slow trek south, I paused in New Bern, North Carolina, to visit an old friend and explore the area. Founded in 1710 by Swiss settlers, it's the "daughter city" of Bern, Switzerland. The downtown exudes rich colonial history the moment you step onto its streets - quaint restaurants, cafes, art galleries, and antique shops abound. We toured the magnificent Tryon Palace, its surrounding museums, impressive architecture, and stunning gardens. Full-time travel keeps delivering these surprises: places you've never heard of that make you think, "Why didn't I come here years ago?"
We devoted a full day to Tryon Palace and its grounds. The highlight was a one-hour guided tour led by docents in period dress who brought the place to life. It reminded me of Colonial Williamsburg - similar feel, but on a much more manageable scale (Williamsburg needs 3–5 days). In the upper-left photo, you'll see the handsome horse stalls; I have a weakness for fine old wood, brick, and craftsmanship. The other three shots show interior details, where our guide did an excellent job explaining daily life for the household and servants.
Built 1767–1770, Tryon Palace stood as North Carolina's first fixed colonial capital and home to Royal Governor William Tryon - under the reign of George III, a king whose House of Hanover was unequivocally German in origin. The dynasty originated in Hanover, Germany, and ascended the British throne in 1714 with George I, a German elector chosen over closer Catholic heirs. This German royal line governed Britain (and its colonies) for nearly two centuries, with George III himself holding dual roles as British sovereign and ruler of the German Electorate of Hanover. Tryon departed for New York in 1771; Josiah Martin followed until his 1775 escape at revolution's outbreak. Patriots then used the Palace as the new state's capitol, hosting foundational General Assembly meetings. The monarchy's deep German ancestry persisted; only in 1917 did King George V rename the house from Saxe-Coburg and Gotha (another German branch) to Windsor to quell wartime anti-German sentiment.
When Governor Martin fled in 1775, he left behind most of his fine furniture. The revolutionaries auctioned it off, using proceeds to fund the war effort. Many pieces ended up with local families. Today, a few originals from Martin's household - along with items tied to first state governor Richard Caswell - have been returned or replicated in their proper places. On tour, you can spot them if you know what to look for; it's a tangible link to that chaotic transition.
Tryon Palace holds a strong collection of 18th- and 19th-century furniture - mostly English, with American examples from New England, Mid-Atlantic, and select North Carolina pieces (heavy on New Bern/Craven County). The American items relate mainly to Josiah Martin's time (1771–1775). A former New York-based officer who married his first-cousin, he included pieces like a Chippendale mahogany desk, pierced-back chair, and large eight-legged dining table - possibly auctioned in 1777 and acquired by Caswell.
The grand staircase was a showpiece - crafted from costly West Indian mahogany that ran 600 pounds (24–30 times an average North Carolinian's annual wage). It highlights the stark class divide: this ornate "canal lever" design (a sophisticated engineering feature) welcomed guests and displayed power, while servants used hidden, steep "lesser stairs." The design literally separated worlds; the social engineering is as evident as the joinery.
This view from a second-floor window shows the well-kept neighborhood - fresh paint, tidy yards, classic homes in fine shape. It was cold and rainy, but we made the most of it and enjoyed ourselves. My bird-savvy friend noticed external bird-themed architecture, which launched us into a lengthy talk about homing pigeons, doves, herons, falconry, and related topics. Always good to have company with specialized knowledge.
The Kitchen Office (first floor: kitchen, scullery, wash house, secretary workspace; second: servants' chambers and laundry) was cutting-edge for 1770 - modern conveniences of the day. It still feels primitive now, but the sights, sounds, and smells of 18th-century cooking are vivid. Daily period dishes use garden produce. The clock jack and weight stood out - similarities to the micro-mechanical timepieces I collect from Switzerland and Germany. Solid engineering for its era.
The North Carolina History Center offers rotating exhibits, interactive displays, waterfront dining, and shopping - aimed at freshening the historic experience. It covers coastal formation to regional shaping. In my view, though, it's a misallocation of funds. After days of classic craftsmanship and quiet elegance, I found it disappointing: stark modern exterior, disjointed interior design, and heavy emphasis on environmental warnings and certain groups' contributions - while downplaying others. The bright colors and constant music felt overwhelming. I shared my thoughts politely on the way out - gentlemanly disagreement is still possible.
Let's close with Tryon’s Latham Garden; a classic formal English-style parterre - flowers, clipped hedges, pathways - evoking 18th-century Britain. Overall, 16+ acres in colonial revival design (1950s, Morley Jeffers Williams) include patterned formal gardens, heirloom blends, a kitchen garden with heritage herbs/vegetables, pollinator-friendly natural areas, and three period houses with distinct themes: camellia-focused lawn, white-themed Georgian, and Southern-style Victorian. A peaceful, well-executed landscape.
This photograph shows the truck after the shop removed it from the lift. They had disassembled part of the rear driveshaft, making the vehicle undriveable, and were uncertain how to complete the u-joint replacement.
A few weeks ago, while departing Virginia, I detected a low rumble in the floorboard at 30–35 mph under normal acceleration - indicative of a rear u-joint starting to fail. Upon arriving in New Bern, North Carolina, to visit a former military colleague, the joint began chirping and squeaking at low speeds, confirming the need for immediate repair.
I briefly considered handling the repair myself, but cold, windy conditions and an estimated hour of labor per joint favored a local shop. That decision proved fortunate. Ram employs a factory process called plastic-injected retention: molten thermoplastic is injected into channels around the bearing caps during assembly, hardening to secure them without snap rings or clips. This provides precise alignment and vibration damping in high-torque truck applications but renders OEM u-joints non-serviceable, intended as lifetime components.
To summarize events thus far: I drove the truck in for a quoted u-joint replacement, with the service writer detailing the OEM plastic retention. After disassembly, they determined they lacked the capability to finish. The vehicle was moved aside to free the bay, I was deferred, and a tow to another facility was offered. During the wait, I gathered information: my son contacted a local Ram dealership service manager; a principal mechanical engineer colleague at NASA LaRC (a muscle car builder) provided input; and I consulted the service manager at a large Ram HD dealership in the Raleigh-Durham-Chapel Hill region.
With the additional details confirmed, I returned to the service writer and outlined the facts calmly: the vehicle was driven in for an agreed repair, partially disassembled (now undriveable), and then completion declined. To the manager, I presented two professional options: finish the work here at the quoted price, or arrange it at another shop for the same amount. The discussion remained courteous as we resolved the matter.
In the end, they sourced and installed a non-OEM u-joint. Though not my first preference, the repair was satisfactory, and I departed under my own power, aware the remaining joint may require attention in the future.
Recommended locally, appears competent in general. The difficulty originated from an early process gap. The local Ram dealership noted that OEM u-joint part numbers are obscured in their system behind a filter requiring manual override - possibly signaling specialized ordering, training, or tooling needs that were not fully relayed to the service writer.
The quotes in order: initial for three OEM u-joints and three hours labor at $795.26 (I later pointed out it is a single rear driveshaft with two joints and two hours); revised to two OEM u-joints and two hours at $539.07; final invoice for one non-OEM u-joint and 1.2 hours at $242.82.
The shop personnel are capable, but an initial oversight escalated into a larger delay. The key lesson is to confirm details early - ensure mutual understanding of the procedure, including any unique methods, tools, or materials. I should have questioned the plastic retention specifics more thoroughly rather than assuming expertise from the quote alone. In the end, all parties gained insight, and I'm now traveling with the lower rear u-joint replaced; the technician noted the upper remains in good condition. Future service may involve refreshing both, or - with this experience - I may handle it myself.
South East Backcountry Discovery Route
Part One of Three
Today, I continue my journey southward along the Southeast Backcountry Discovery Route, a trail spanning roughly 1,300 miles through the diverse landscapes of the Southeast. For me, it begins in Damascus, Virginia - "Trail Town USA" - where it links to the Mid-Atlantic BDR, then winds through the Appalachians of North Carolina, Tennessee, North Georgia, Alabama, and across the Florida Panhandle, ending on the shores of the Gulf of Mexico. This SEBDR marks the end of my East Coast Trilogy - interconnected routes from Gulf to Canada - and I share it to inspire you: shed the chains of safety and truly live.
As I crossed into Cherokee National Forest's 660,000 acres of Southern Appalachian splendor, the route had me switching repeatedly between south- and north-facing slopes. Remember, weather and timing can make opposites similar or starkly different. In my case, south sides were often frozen dirt and gravel, reliable under tire, but north faces brought packed snow, slick ice, and minimal hold - a reminder that nature's whims demand respect.
It was heartening to see signs of recent passage, from rangers or locals attuned to local conditions. Days earlier, milder weather might have melted snow slightly before a hard freeze locked it in. Despite shifting from icy miles to firm dirt and gravel, I held off on my PEWAG chains. Lowering tires to 25 PSI, I navigated carefully - part of the deliberate daring that defines adventure.
Maintaining 15-20 mph through spots made good time toward my 100-mile daily target, wrapping the route in two weeks to match Florida schedules. Still, the hassle of chaining multiple times daily could extend it, leading me to ponder if winter was ideal. Over to the west, the 7,580-acre South Holston Lake, a TVA creation, shines as a premier smallmouth bass spot and fly-fishing paradise, a testament to the wild's rewards.
Descending from the heights into historic Elizabethton, Tennessee, felt refreshing, but reality hit: Section 10 spanned 148 miles, and I'd covered only 60, lagging my 100-mile pace. Founded in 1799 and incorporated in 1905, Elizabethton is Tennessee's first town, dubbed "The City Where Independence Began" - the initial independent government west of the Appalachians. At the Doe and Watauga rivers' meeting, it features the 1882 Covered Bridge, Sycamore Shoals State Historic Park, and the Overmountain Men who marched from there to the Battle of Kings Mountain.
From Elizabethton, a short southern jaunt turned southwest across the Tennessee line into North Carolina, entering Pisgah National Forest's 500,000+ acres of lofty peaks, waterfalls, and forested hills, dominated by hardwoods, rivers, and extensive trails. This forest sparked the eastern national system with its inaugural land buy, housed the nation's first forestry school (preserved as Cradle of Forestry), and claims two pioneering eastern wildernesses - sanctuaries calling me to explore and share the wild.
A caution for solo mountain ventures in foul weather, where traction can vanish, stranding you in danger: best to team with one or two equipped rigs, check ranger stations for updates, stick to daylight, and test grip often. Simple checks - like braking sharply in safe spots or accelerating in two-wheel drive - reveal surface hold, and since it shifts quickly, test frequently. If unsure, edge the ditch side (right here) to slide safely, not over cliffs - engineer prudence into your pursuits.
In late September 2024, Hurricane Helene's remnants unleashed devastating floods on eastern Tennessee and western North Carolina, pouring 20-30+ inches of rain in days over the Appalachians. This sparked flash floods, landslides, and river rampages that crushed infrastructure, damaging over 670 bridges in North Carolina and many in Tennessee, with waters washing away spans, eroding bases, and scouring paths. Once-calm rivers became monsters exceeding design thresholds, a humbling lesson in nature's might.
This catastrophe highlighted water's overwhelming force against human builds: concrete bridges, designed for loads and standard floods, succumbed to hydraulic might, debris impacts, and undercutting from extreme surges. Many areas surpassed 500- or 1,000-year flood marks, showing infrastructure's limits versus a stalled storm's deluge. Billions in repairs continue into 2026, a reminder that nature can shatter the permanent.
Winter solitude in these ancient forests is a lover’s embrace and a blade at the throat at once - this is an act of deliberate vulnerability: cell service fades, snow buries the road, and beauty arrives in stark, indifferent doses - ice-rimed ridges, frozen silence, vast white emptiness. Yet peril is never far; a fraction of lost traction on a descent and the slide begins - unhurried, merciless - toward wreckage or worse, leaving you injured or not, but always alone. Such risks are not recklessness; they are sacraments of aliveness. As St. Thomas Aquinas taught, true virtue often lies in measured daring; as St. Augustine of Hippo confessed, the heart knows no rest until it risks itself for something greater than safety. We must fear not dying, but dying having never lived.
Part Two of Three
I had a decision to make: all the weather forecasts I sourced warned of a historic winter storm obliterating the mountainous area of eastern Tennessee and western North Carolina in the coming days. I read this objectively, realizing the role of news organizations is not necessarily to provide accurate and useful information as much as to make money for shareholders. I spent hours researching maps, examining routes for the next few days, and estimating descent times from any spot to a nearby town or village for shelter. I considered remaining in the mountains with enough food, water, and fuel for my diesel heater, but though it sounded rugged and romantic, staying in unfamiliar terrain with limited cellular service amounted to an unnecessary risk.
Tucked along a quiet mountain road in Collettsville, North Carolina, Betsey’s Ole Country Store feels like a step back into a gentler, slower-paced past. Housed in a weathered building rooted in the early 1900s, it carries the spirit of old Mortimer, where front-porch conversations and neighborly stops defined daily life. Today, it’s a beloved spot for locals and travelers, offering simple staples, cold drinks, and nostalgic hot dogs to hikers, anglers, and wanderers heading for Wilson Creek and Pisgah National Forest. With creaking floors, mountain backdrop, and timeless hospitality, Betsey’s isn’t just for provisions - it’s a living memory of rural Appalachia and small-town North Carolina’s charm.
Nestled high in the Blue Ridge, Newland marked a quiet threshold along the SEBDR, transitioning from Section Ten to Nine - I’d completed 148 of 1,300 miles. Normally, it might invite a slower pause: a warm meal, a lingering look at darkening ridgelines. But that night, pressure mounted with a massive winter storm hours from engulfing the region. To stretch progress before conditions worsened, I rolled into a gas station minutes before 2300, likely their last customer under humming fluorescent lights. I refueled the truck and, breaking habit, grabbed energy drinks for alertness if the trail demanded more. Necessity, not comfort, guided the stop.
Just over two hours later, deep into the night, a seasonal gate stopped me - the GPX file from Backcountry Discovery Routes showed it closed December through mid-March, but I tried anyway. I understood the closure: elevation rose quickly to just under a mile high, with annual snow making it too dangerous open. Secretly, I’d envisioned the gate ajar, stopping to install my 140-pound PEWAG 8.2 mm square-link chains on 37x12.5 tires, crawling through tank-like at a few miles per hour. My concern? Crossing the highland only to hit a locked opposite end. Imagine turning a twenty-foot vehicle around on a ten- to fourteen-foot snow-packed shelf road after fourteen hours’ drive? That wouldn’t be fun - I’d likely park and wait for daylight. The closed gate was strike one; two more along the SEBDR meant scrubbing the mission for another time. At only 15% in, odds weren’t favorable, but I’d take the chance.
I studied my maps, dropped off the mountain, and found a detour for the short closed section: west a few miles to Unicoi, southwest to Erwin, Tennessee. It was the wee hours as I stopped in town, rolling down windows for fresh air. The place was dead, nothing moving but fast traffic nearby - Interstate 26. So late and tired, I needed a pullover spot soon. I came upon idling 18-wheelers outside town, but checking the map, I spotted a rest stop miles south. Pulling in, only one other car was there - perfect for quiet rest with another long day ahead. Waking in the morning, stepping out to stretch, I met a smiling girl in her early 20s, also full-time traveling in that car. I don’t recall her name, but I’ll call her Jabber-Jaw, that girl could talk endlessly. She said she awoke when I arrived, relieved after feeling scared alone in the lot. We chatted; I encouraged her to continue adventuring, find a husband, start a family.
Not all overland miles are gravel and stone; along the SEBDR, occasional smooth two-lane pavement felt less like compromise and more like a gift. These roads swept through rolling countryside and mountain communities, revealing barns, valleys, and ridgelines rougher tracks hide. Far from diminishing, these sections affirmed overlanding is about the journey as much as the surface. As counterbalance to punishing rock and ruts, they added rhythm and variety - likely no more than 10 to 15 percent of my southbound miles so far, a modest contrast in a demanding route.
I noticed a pattern: on average, below half a mile elevation (2,640 feet), no real snow or ice concerns. North faces always had more than south, so dirt and gravel might carry higher on south sides, while north encountered it lower. Depending on face perpendicularity, differences exaggerated. Some call this relating to nature; I see it as common sense we all have but rarely use. A key travel insight: groups bring radio chatter, vehicle spacing, stop coordination for food or camp - cluttering an immersive journey. I’m not negative on groups, but reinforcing our instinct to travel alone, immersing in the natural world.
Traveling over Bald Mountain north of Hot Springs, NC, felt like ascending into another season. The Forest Service road climbed the north face, hard-packed and ice-glazed, demanding patience with each turn. Towering rhododendrons closed in, forming a glossy green tunnel unreal against frozen brown earth. The contrast struck - vivid life in winter’s dead, ancient shrubs defiant amid ice, shadow, cold. Air hushed and heavy, tires spinning softly upward, it felt like passing through hidden sacred space, a corridor where winter loosened grip enough for green to endure.
At its core, "The Winners" reflects Kipling’s belief that progress and strength forge in solitude, not crowds. The line “He travels the fastest who travels alone” echoed as I rested by a creek, tracing gnarled roots gripping earth. That mirrored my path - years of solitary work, including jumps from helicopters into dark ocean, aircraft fading so I worked undisturbed. Kipling’s poem isn’t lonely; it’s resolute, arguing we must learn aloneness without diminishment, act decisively sans reassurance, stand firm when noise fades and responsibility remains.
I found myself beside Paint Creek again, picking across rough slick stones, cold seeping through boots as I paused to absorb it. Across a wide, slow bend of partially frozen water, a waterfall whispered and thundered, forty feet away yet another world. Air crisp and clean, pine-scented, softened by canopy light, grounded by stone’s bite. The sound - steady, alive, magnificent - no recording captures without losing soul. Sitting there, I wished to hand it to you like warm coffee on cold morning. Instead: this weekend, explore. Even briefly, map a forest, park, wildlife area - federal, state, local. Your current vehicle is right. Join birds, fish, quiet woods watchers; immerse in the world our Father created for enjoyment. Happy trails.
Solar System Monthly Validation Report – January 2026
This report presents the system validation and verification results for my solar power system and battery bank after 153 days of off-grid travel. The sole power source consisted of two 250-watt solar panels (Rich Solar) connected to a solar charge controller (SmartSolar MPPT 100/30) and a 200 Ah battery bank (two LiTime 12V 100Ah Group 24 Deep Cycle LiFePO4 batteries). Neither the AC-DC charger (Blue Smart IP22 Charger 12V-30A) nor the DC-DC charger (Orion XS 12/12-50A) was used during this period. The objective was to evaluate the adequacy of the solar system and battery bank capacity to support off-grid travel demands.
System validation and verification for a vehicle’s solar-based electrical system involves confirming that the setup meets design specifications and performs reliably under anticipated operating conditions. Validation ensures the system addresses the intended purpose (e.g., providing consistent power for off-grid requirements), while verification confirms proper integration and functionality of components. This process is critical for my setup, where approximately 50% of operation occurs under forest canopy (reducing solar input) and 50% in semi-open areas with partial sunlight, enabling early identification of inefficiencies.
The histogram below illustrates the maximum state-of-charge (SOC) achieved by the battery bank during each 24-hour cycle. Over the most recent 31-day period, the maximum SOC ranged from 78% to 100%, with 28 days recording values between 90% and 100%. Although I did not log the specific times when SOC reached 100%, this value was frequently attained around midday. These results indicate that the system has sufficient solar capacity for most of January's operating conditions. It will be valuable to assess performance during February and March, when solar input slowly continues to rise. Overall, I am satisfied with these findings, as the system exceeded the design goal of providing sufficient power for seven days using solar energy alone, successfully delivering power for the entire 153-day period.
The histogram below illustrates the minimum SOC achieved by the battery bank during each 24-hour cycle. Over the most recent 31-day period, the minimum SOC ranged from 70% to 92%, with 21 days recording values between 80% and 90%. The minimum SOC was typically reached early in the morning, just before sunrise. During the system design, my goal was to ensure the SOC rarely dropped to 25%. The fact that the lowest recorded SOC over the 31-day period was 70%, with all other values higher, demonstrates the system’s robust performance.
The screenshot below, captured from the Victron Energy solar charge controller, displays the energy collected by the system over the past 31 days. The white portion of each column represents the percentage of time spent in Bulk charge mode, while light blue indicates the Absorption phase and medium blue denotes the Float phase. The data shows that the system reached the Float phase on one-third of the days. This indicates that the system was fully or nearly fully charged for approximately one-third of the time.
This period represents one of the lowest solar resource times of the year, with reduced exposure duration, oblique rays, and higher chances of overcast skies further diminishing power production from solar panels. On December 01-09, snowy and overcast conditions limited solar input, while on December 10-11 the system dipped even lower with heavy overcast. On December 12 the system quickly recovered pulling in as much as 1.07kWh on a single day. Despite the wide range of overcast, partially cloudy, and clear days, coupled with temperatures that ranged from the 21°F through 74°F, the system, the system performed better than expected throughout the most challenging time of the year for a solar system. On days when the temperatures dropped below freezing, I was able to maintain the battery temperature above freezing by leaving the door to the battery compartment open at night while my diesel heater ran.
This data is associated with the chart above. I attempted to attach the CSV file to this post for further review but the uploaded file does not have an allowed extension.
I will periodically measure system performance and publish updates similar to this report. Evaluating the system’s behavior over the coming years will provide valuable insights into its long-term performance and alignment with design expectations.
Part Three of Three
I’ve long suspected that many of us carry an ancient, almost instinctual tie to water - as a source of life, sustenance, and refuge. It seems to quiet the mind and body in ways that are hard to quantify. From my years on and around the water during service, I can attest that the sight and sound of it reliably lowers heart rate and blood pressure. In those moments, immersion brought a rare clarity - a focused calm that felt like being truly in the zone. My modest advice, when the trail brings you to a river, lake, or stream, is simple: pause. Share a meal there, or better yet, spend the night. For many, the steady rhythm of waves or flowing current offers a gentle, unintrusive backdrop that lets the brain step away from accumulated stress.
These were my final miles paralleling the French Broad River before reaching Hot Springs, North Carolina - the end of Section Nine on the SEBDR. It was a sobering realization: in roughly two and a half days, I had covered only 262 miles, with more than 1,000 still ahead. At least Hot Springs promised reliable cell service, allowing me to check forecasts for the approaching winter storm. While much of the recent trail had demanded careful, deliberate progress, other stretches permitted reasonable speed. The central question remained whether I could move quickly enough to stay ahead of the storm’s worst effects.
Continuing south from Hot Springs, I crossed back into Tennessee and entered the Cherokee National Forest, climbing steadily after passing through the open gate at Locust Gap. The icy conditions here were the most challenging yet; exposed dirt appeared only rarely. Section Seven spanned just 77 miles, but nearly all of it wound through mountainous terrain, and from what I had encountered so far, roughly 80 percent was glazed with ice. I advanced methodically, making steady if slow gains, though the schedule continued to slip.
Then came a full stop. At Rattlesnake Gap, I found myself on the wrong side of a closed gate. Had I inadvertently traveled a restricted section? Given the deteriorating weather and storm’s imminent arrival, the closure made sense - but why hadn’t the gate been secured at the entry point miles earlier? Confusion set in, so I paused to think things through carefully. I gained elevation to a nearby ridge for better signal, contacted the Cherokee National Forest ranger station, and the situation only grew more complicated.
The Cherokee National Forest comprises four ranger districts, and coordination among them appears limited. I explained my position - providing precise latitude and longitude - to the first office, only to be directed to another, and then a third. The third acknowledged I was in their jurisdiction but noted that most staff had already left early to prepare for the storm. The ranger was courteous and confirmed their office was several hours away. He suggested contacting the local sheriff for evacuation, leaving the truck in place until conditions improved in a week or so. When I asked about the prospect of a foot or more of snow covering the trails, the line went quiet for a long moment. The Forest Service disclaimed responsibility and offered no clear explanation for the incomplete gate inspection. Ultimately, I had placed myself in this position, so the responsibility to extract myself rested with me.
After walking the trail back a quarter mile or so, I identified the safest spot to attempt a turnaround on the narrow 10 - 14-foot shelf road - near the gate itself. With a plan in place and daylight waning, I took a moment to eat, rest, and review options. Experience has taught me that rushing into solutions during adversity often compounds the problem. I measured distances, rehearsed maneuvers mentally, and considered contingencies. I would reverse with the rear of the truck oriented downhill and the nose elevated; if needed, trees on the high side could serve as winch anchors. The opposite orientation - nose downhill - would only pull me deeper into difficulty. I positioned a large tree directly behind as a natural stop if slippage occurred. I was grateful for the Warn 16,500-pound winch, the full AEV recovery kit, and the clear view provided by the OEM backup camera on the camper.
After what felt like a record-setting ten-point turn, I was underway again under my own power, heading downslope. Before ending the call, the ranger had authorized cutting the lock in an emergency to reach safety. I appreciated the gesture but noted that the gate’s security features made accessing the lock impractical without specialized tools. In hindsight, I’ll pay closer attention to gates in the future and consider carrying an appropriate emergency tool. Temperatures continued to fall, making the trail progressively slicker, but gravity was now an ally as I descended. Still, this marked strike two for the trip - roughly 300 miles covered, 1,000 remaining - and the outlook felt increasingly uncertain.
Back in Hot Springs, I powered up the laptop to assess upcoming trail status - open or closed? While researching, three adventure bikers arrived, sparking brief hope that they had just completed the section I intended to tackle. Their bikes and gear showed no signs of recent hard use - no dirt, no weathering - and they confirmed they had been on pavement for a day ride out of Asheville. Pleasant fellows, but the information left me once again navigating solo, without reliable intel on conditions ahead.
I rerouted around the closed section onto well-maintained forest service roads, where speeds settled comfortably between 10 and 20 mph, often closer to 15 - 20. Momentum returned; perhaps an all-night push could outpace the storm. During a trail-side break, reality settled in. The next SEBDR segment - from Maggie Valley to Tellico - was 165 miles, much of it through Nantahala and Cherokee National Forests again. Beyond that lay nearly another 100 miles to the Georgia border, where past experience on the Georgia Traverse and Georgia Adventure Trail had shown the northern region to be rugged and demanding. The notion of outrunning the weather was wishful thinking - one major storm approaching, two strikes already, and 1,000 miles to go.
Strike three. I carry certain qualities - resilience, mental toughness, perseverance, a refusal to quit when the odds stack high, adaptability, self-belief, competitiveness, stoicism, and stress resistance. I know these traits serve well when circumstances turn against me. Yet I also live by a mission, self-discipline, and a set of personal rules designed to preserve life and capability for the longer term. As difficult as it was to accept, my rule is clear: strike three means withdraw. It is a safety boundary that has kept me intact through close calls in the past. I hold no fear of the end - sometimes I feel I’ve already crossed that threshold in spirit - but there remains work to do here, a purpose to serve. Until directed otherwise, I continue forward on the path laid out. The SEBDR will wait for another season. Happy trails, gentlemen.
I hate giving up. I also have learned to listen to the little alarm buzzer in my brainstem that tells me what I'm about to do is a bad idea.
"Good judgement comes from experience, and experience comes from poor judgement?"
I agree with you in large part, and I really appreciate the reminder - I've come to trust that little alarm buzzer in my brainstem too. It’s saved me more than once. And yes, your closing line is spot-on: "Good judgement comes from experience, and experience comes from poor judgement." That's wisdom worth repeating.
One thing I probably didn't emphasize enough is how blocked sections change the whole game for me. When large parts of the trail are gated, washed out, or otherwise impassable, I can't truly experience or report on the route accurately. I'm not a content creator by any stretch - no chasing sponsors, no monetizing views, no hype for clicks. I just enjoy the trails, snap a few pictures along the way, and share a few honest paragraphs about what I actually saw and did. Everything I run - truck, camper, recovery kit - is bought with my own cash after real research, and someday I plan to post honest, long-term gear reviews based on years of actual use, not quick impressions.
Right now, my focus is exploring trails fully, wandering museums, chatting with locals, and just soaking in the journey. When I post about a trail, you can count on me having covered every mile (and then some) myself. It's funny - when I talk with actual content creators at shows, they tend to stay vague on specifics like "Where exactly did you camp in section five?" or "How deep was that river crossing?" They prefer broad strokes; I prefer the full, accurate story.
So yeah, the mission got halted this time - not quit, just scrubbed for now. It means rethink, reassess, replan. I picked a tough window: wrong time of year, plus that freak storm rolling in and paralyzing sections ahead. Sticking to my rules meant recognizing that in its current state, pushing on would've made a full, honest report impossible. But I'll be back, and I'll finish the SEBDR like so many others have. The trail isn't going anywhere.
Happy trails - stay safe out there!
The Museum of Aviation sits right next to Robins Air Force Base in Warner Robins, Georgia. It’s the second-largest U.S. Air Force museum and one of the most visited in the Department of Defense. The 51-acre site includes four climate-controlled exhibit buildings housing over 85 historic Air Force aircraft, missiles, cockpits, and interpretive displays covering more than a century of aviation history. Best of all, admission and parking are free.
The American Volunteer Group - better known as the Flying Tigers - was a remarkable outfit formed in 1941 with President Roosevelt’s approval to help China defend against Japanese invasion during the Second Sino-Japanese War. It consisted of volunteer American pilots and ground crew (pulled from the Army Air Corps, Navy, and Marines) who flew Curtiss P-40 Warhawks under the Chinese Nationalist Air Force banner. Those P-40s, with their famous shark-mouth nose art and Chinese insignia, racked up impressive combat scores with innovative tactics that played to the aircraft’s strengths in diving attacks and toughness. This pre-Pearl Harbor effort was really an early proxy war: U.S.-authorized, indirectly funded and supported, yet kept at arm’s length to preserve official American neutrality until the war began.
With my mechanical background, I’ve always been pulled toward displays that let you see inside complex machinery. The cutaway of the Pratt & Whitney R-4360 Wasp Major radial engine is a perfect example: it lays bare the 28 air-cooled cylinders arranged in four staggered, semi-helical rows (hence the “corncob” nickname for excellent cooling), along with the big crankcase, geared supercharger, and propeller reduction gearing - all in one clean cross-section. At 4,362.5 cubic inches and up to 4,300 horsepower, this was the largest-displacement piston aviation engine the U.S. ever mass-produced, and it marked the high point of big radial technology from late World War II onward. For someone who still thinks in three dimensions, these sectioned views turn dry specs into something you can almost feel working.
The Vultee BT-13B Valiant has its port-side cockpit panels removed, exposing the complete set of internal control linkages - rods, bellcranks, cables, pulleys, and torque tubes - that carry pilot inputs out to the flight surfaces. It’s a straightforward, rugged mechanical setup, built to hold up under constant vibration and the inevitable rough handling that came with student pilots.
While I was visiting, the museum was hosting a student robotics tournament in the Century of Flight Building. Middle and high school teams showed off their FIRST LEGO League and similar robots, competing on innovation, performance, and core values while tackling engineering and problem-solving challenges. An inset photo shows the Explosive Ordnance Disposal display upstairs, with gear, uniforms, a bomb suit, training munitions, a robot, and photos.
The main shot is of the Sikorsky HH-3E Jolly Green Giant - a tough, heavily armored combat search-and-rescue helicopter best remembered for Vietnam missions under the motto “That Others May Live.” Built on the S-61 airframe, it had self-sealing tanks, defensive guns, a rescue hoist, and in-flight refueling to pull downed crews out of harm’s way. The lower-left inset is the smaller Kaman HH-43F Huskie, a local-base rescue and firefighting bird with its distinctive intermeshing rotors and Fire Suppression Kit. The lower-right inset shows a USAF O-11A Crash Fire Rescue truck - classic ground-support equipment you’d see responding to emergencies on bases.
The North American Rockwell OV-10A Bronco is a twin-turboprop light attack and observation aircraft from the 1960s, designed for counter-insurgency and forward air control with excellent short-field performance, a high wing and twin booms, and a big greenhouse canopy for outstanding visibility. Powered by two Garrett T76 engines, it could haul guns, rockets, and bombs while staying agile at low speeds - perfect for Vietnam close air support. I’ve always thought it looked like a really enjoyable machine to fly: small, sporty, responsive, and with that panoramic view it must have felt like a high-performance aerial scout you could toss around the sky with real satisfaction.
The Lockheed SR-71 Blackbird program, born in the early 1960s at Skunk Works, remains one of the greatest achievements in aerospace engineering for strategic reconnaissance. Its titanium airframe could sustain Mach 3.2+ at altitudes above 85,000 feet, driven by twin Pratt & Whitney J58 turbojets with afterburners and variable inlet geometry, while advanced sensors gathered electronic intelligence and the aircraft’s speed and tiny radar signature made it nearly untouchable. Tail number 17958 was the first operational SR-71A handed over to the Air Force in 1965. The “ICHI BAN” marking - Japanese for “number one” - and the red-and-white tail art of a white Habu snake coiled around a big red “1” were a quiet tribute to the fleet’s mission excellence.
Looking out the back window of the museum, you see several big transport types parked outside, including the swept-wing C-141C Starlifter and the unmistakable C-124C Globemaster II with its clamshell nose. There may be an E-8C Joint STARS in the lineup as well. These outdoor static displays, spread across the 51-acre grounds, trace the long evolution of strategic airlift.
The Lockheed AC-130U Spooky gunship - derived from the C-130 Hercules and known across variants as Spectre, Spooky, Stinger II, or Ghostrider - combines side-firing guns and sensors to deliver precise, persistent close air support. The fuselage section displayed inside the Eagle Building shows the classic armament suite: the GAU-12/U 25mm Gatling for rapid suppression of soft targets, the 40mm L/60 Bofors for anti-armor and area work, and the M102 105mm howitzer for heavy, high-explosive strikes on bunkers and vehicles. All three weapons are synchronized by a fire-control computer so the aircraft can orbit in a pylon turn and pour concentrated fire onto one spot with very little scatter. The optical targeting pod, with its three spherical lenses (infrared, low-light TV, and laser rangefinder), provides day-or-night target acquisition, tracking, and illumination even in poor visibility. The whole system’s strength is its ability to loiter and deliver lethal, accurate firepower while keeping collateral damage low through sensor-guided corrections. I saw this capability up close years ago when I was stationed near Eglin AFB and would regularly drive over to Hurlburt Field, headquarters of Air Force Special Operations Command and home of the 1st Special Operations Wing, to watch AC-130s working the ranges. There was nothing quite like hearing the fast, rhythmic chatter of the 25mm Gatling followed by the heavy, deliberate booms of the 105mm howitzer kicking up dirt plumes, all while the crews sharpened their skills in close air support, interdiction, and armed reconnaissance. It was raw power married to remarkable precision, and it always left a lasting impression.
As I drove the narrow backroad through the Okefenokee Swamp, thick smoke stung my eyes and carried the sharp, resinous tang of burning pine sap mixed with scorched earth. Tall longleaf pines and cypress threw long, inky shadows across the asphalt in the low light, while thin gray-blue plumes rose twisting from glowing underbrush - wiregrass and palmetto crackling and popping with tiny bursts of flame. Heat pulsed through the open window, warm and smoky, clinging to my skin and throat. This low-intensity prescribed burn cleared dead fuel, let sunlight reach pine seedlings, and returned nutrients to the sandy soil, sustaining the fire-adapted pine flatwoods and prairies in their slow, natural renewal.
As evening settled over the swamp, I crept down the tight, twisty sand road with headlights slicing pale beams through the thickening dusk, the sky fading to a thin strip of bruised purple above the canopy. The narrow path twisted sharply between walls of dense, overgrown undergrowth - thick tangles of palmetto, gallberry, and sawgrass pressing close, their fronds and branches scraping the truck’s sides with dry rasps and clawing at the mirrors. This immense blackwater wilderness, over 400,000 acres straddling southern Georgia and northern Florida, has long been a refuge for the hunted: Seminole warriors and escaped enslaved people vanished into its maze during the 19th-century wars, evading U.S. troops; later, moonshiners and fugitives hid stills and secrets among the peat bogs and pine islands, while scattered skirmishes flared in its remote pockets. With night closing in fast and no campsite yet in sight, I scanned the dim edges for a pull-off to spend the night.
The Okefenokee Swamp unfolds in an almost intoxicating natural beauty - this primordial wilderness, largely preserved in its raw state, stirs a deep sense of awe and peace that lingers long after you leave. I urge you to bring your family and experience it firsthand: the north entrance features Okefenokee Swamp Park (near Waycross, GA), with its guided boat tours, nostalgic train rides through pine flatwoods and prairies, live reptile encounters, and interactive exhibits that delight adults and especially children; the east entrance (Suwannee Canal Recreation Area near Folkston, GA) is home to Okefenokee Adventures, offering naturalist-guided boat tours skimming close to wildlife, kayak/canoe rentals, and interpretive programs that make the swamp’s ecology vivid and engaging for all ages - turning a simple visit into an unforgettable, educational escape into one of America’s last great wild places.
The Chesser Island Boardwalk in the Okefenokee National Wildlife Refuge is a serene 0.75-mile (one-way) elevated wooden path that glides through haunting blackwater swamp: ancient cypress draped in ghostly Spanish moss, dense palmetto thickets, and open prairies where sunlight dances on lily pads and dark water. The weathered planks creak softly past shaded alcoves buzzing with frogs and dragonflies, offering prime, safe views of alligators, herons, and other wildlife. At the end rises the Owl’s Roost Observation Tower, a 40-foot wooden structure climbed by stairs to a sweeping 360-degree panorama - shimmering Seagrove Lake edged by emerald prairies, distant tree islands like green mirages, and the vast, untamed swamp stretching endlessly beneath wide skies - perfect for birdwatching or absorbing the wild beauty from on high.
While hiking the boardwalk, I rounded a bend and paused: a bobcat strode straight toward me on the wooden planks, treating the elevated path like its private superhighway through the swamp. I figured these cats use boardwalks for swift, dry travel across the flooded wilderness while stalking rabbits, birds, or rodents. Its tawny coat rippled under shifting cypress light as I moved closer, 30 to 40 feet, unfazed, our eyes locked. Then it broke out stare-down, ears swiveling, muscles coiling as it fixed on prey in the brush below. In a heartbeat it launched off the walkway into the dense tangle, vanishing without a sound. Adrenaline surged; I half-hoped it would whirl back and charge, already picturing the scars that would stripe my arms, face, or neck as fierce, lifelong trophies of the clash. Instead, the swamp swallowed it whole, leaving only the pounding thrill of that razor-close encounter.
This time, I camped at the primitive East Tower Hunt Camp in Osceola National Forest - quiet, pine-shaded, and basic, with just enough space for real solitude. I’ve stayed at West Tower before, enjoying its horse stalls, seasonal flush toilets, and trail access. Soon I plan to try Cobb Hunt Camp near Olustee Battlefield for its backcountry feel and Florida National Scenic Trail connection, then return to Ocean Pond Campground for lakeside sites, a swimming beach, fishing, and hot showers. Each spot delivers its own slice of the forest’s peaceful, pine-scented wilderness.
The Auto Skills Center at NAS Jacksonville serves as a comprehensive do-it-yourself facility for military personnel, their families, and eligible patrons. It features 22 work bays equipped for a variety of automotive projects, allowing users to perform repairs and maintenance at a fraction of commercial costs. The shop offers an extensive tool checkout system, providing access to a wide array of hand tools, power tools, and diagnostic equipment without the need to bring your own. Additionally, an ASE-certified master mechanic is on staff to offer expert guidance, ensuring even novice hobbyists can tackle tasks safely and effectively after completing a mandatory safety orientation.
Beyond the basics, the Auto Skills Center boasts specialized equipment like wheel balancing machines for precise tire and wheel servicing, a dedicated paint booth for professional-quality refinishing, and welding stations for metal fabrication and repairs. During my visit, I utilized the facility to investigate unusual noises emanating from my front drive shaft, focusing primarily on the ball and socket CV joint near the transfer case rather than the u-joint closer to the axle. The shop's resources helped me diagnose potential wear in its components.
In the mid-1980s at NAS Jacksonville’s HS-1, fresh grads in their late teens or early 20s endured nearly 1.5 years of one of naval aviation’s toughest pipelines to emerge as qualified rotary-wing aircrewmen and Aviation Rescue Swimmers (Naval Special Operations). The gauntlet - boot camp, aircrew candidate school, ASW operator “A” school, SH-3H Sea King quals, survival swimming, rescue hoisting, SERE, and the infamous Aviation Rescue Swimmer School - boasted washout rates often exceeding 75–85% in the final phase alone, thanks to brutal open-ocean swims, helo deployments in heavy seas, extreme water-confidence drills, and high-stakes decision-making under relentless stress. Graduation meant earning the gold Naval Aircrewman wings in a formal ceremony. The real rite, though, erupted at Mulberry Cove on the St. Johns River: new crewmen dropped their wings into a pitcher of beer, chugged it down to clutch the pins in their teeth, then bared their chests as seniors from every other active helo squadron lined up. With clips removed, the wings were slammed into flesh in a savage contest - each man hammering harder than the last, drawing blood, leaving bruises and punctures as badges of unbreakable brotherhood amid cheers, beer, booming 80s rock, and river breezes - this is for you Tony.
My brother in the sky and sea - we bled together, laughed through the storms, shared the roar of rotors and the sting of salt. You were more than a shipmate - you were the brother I chose, my wingman, my jump partner, my closest friend. Your quiet bravery jumped into the unknown time and again so others could live. Today the ocean claims one of its own, but your sacrifice echoes in every life saved. Your courage was steady, selfless, unbreakable. Fly high, swim deep, brother - 'So Others May Live,' and you did, until the very end. Mission accomplished.
While at Planet Fitness in Lake City, Florida - one of my go-to spots for a workout, shower, and massage - I waved at another traveler and got a friendly howdy back. Turns out Scott’s from Idaho, which reminded me of my late buddy Tony from Coeur d’Alene. We swapped road stories and plans, and I invited him to tag along. After checking fuel, tires, and temps, we headed into Ocala National Forest. This photo is us at Hopkins Prairie Campground - shady oak site overlooking the prairie. I rarely pay to camp, but splitting the site fee with Scott made sense, especially since I was meeting a couple friends I hadn’t camped with since last year.
One of them was Paul from Massachusetts, who just finished his first full year full-timing. When we met years ago, he had a Palomino motorized pop-up that looked good but was trouble - the roof motors were slow, got out of sync, let rain in, and eventually failed. The whole unit wasn’t built for constant use and was falling apart. Paul always liked my Four Wheel Camper, asked questions, checked it out, and finally switched. After a year, he’s happy - says it’s reliable, simpler, and holds up far better for the long haul.
How many guys drive deep into a national forest on a chilly February night to watch the Super Bowl - and don’t really care who wins? Paul set up his TV, Matt got Starlink going, we cooked plenty of food, and had a relaxed time. Funniest moment: Paul’s chair collapsed during a big play, tipping him sideways and smashing a full beer can - foam everywhere. We laughed; no big deal. Next morning the camp host chewed us out for four vehicles in a two-vehicle site. We were leaving anyway, but Paul was a bit miffed - he’d known the host for years and said the two-vehicle rule gets bent all the time here.
Together we spent a few days exploring Ocala’s 442,000 acres - lakes, rivers, streams, and trails. It’s not the most dramatic forest I’ve seen, but the mild winters make it great for camping, and the wildlife is solid: Florida’s largest black bear population, scrub jays, alligators, deer, plus foxes, raccoons, otters, gopher tortoises, armadillos, and more through oak hammocks, palms, and cypress wetlands. Good spot to slow down and relax after months of bitter cold.
We moved to camp near the U.S. Navy’s Pinecastle Range Complex - a 6,000-acre active bombing range in the forest near Astor, operating since 1951. It’s the only East Coast spot for live and inert air-to-surface training, with a simulated airfield and targets. We hoped to catch some drops from outside the restricted area - F/A-18s, helicopters doing rockets, bombs, and gunnery. The booms roll through the trees and hit you in the chest. I respect the precision - and the noise keeps these ranges remote for good reason.
The Battle of Olustee, February 20, 1864, was Florida’s biggest Civil War fight - about 5,500 Union troops under General Seymour versus roughly the same number of Confederates under General Finegan in the pines near Ocean Pond. Union goals were to cut supply lines, secure northern Florida, and recruit Black soldiers, but they got stopped after pushing west without good scouting. Five hours of fighting ended in a Confederate win - 1,861 Union and 946 Confederate casualties - forcing a retreat to Jacksonville. The annual reenactment at Olustee Battlefield Historic State Park brings it back with thousands watching. This photo of four older folks at a picnic table in period garb shows the camp vibe - soldiers, civilians, and vendors mixing like 19th-century army life.
The reenactment dives into the era’s material world with dozens of vendor tents selling authentic reproductions - uniforms, tents, rifles, cooking gear - all built to high standards and priced for the detail. Sutlers keep authenticity tight; there’s the old line: “If it didn’t come from Olustee, it ain’t worth a damn.” It shows the investment folks make to get it right, just like soldiers relied on solid gear in Florida’s tough terrain. This shot inside a busy tent highlights the supply side - logistics mattered then and still do.
As the event builds, hundreds of Confederate reenactors march from camp toward the field, line after line through the pines. It captures the original scale, where Finegan’s men held lines to block Seymour’s advance. The reenactment draws 1,500–2,000 participants from across the country - each putting in hundreds of hours and thousands of dollars on gear for full immersion. This formation recalls the reinforcements that turned the tide. It’s a living tribute to the 10,000-plus who fought here.
Artillery was critical at Olustee - cannons thundering on both sides, adding chaos and casualties as Union lines broke against Confederate works. The reenactment shows it well with crews running replicas like this ten-pound brass piece: six men drilling clean, load, fire, cool - precise and practiced. When it fires, the ground shakes and the concussion hits your chest, just like back then. This photo captures the professional side - timing, safety, teamwork - and how the event teaches the tactics that held Florida’s interior for the Confederates.
Here’s sunset over Hopkins Prairie in Ocala National Forest. After the miles, the visits, the history, and the distant booms, these quiet evenings make full-timing worth it. The prairie opens wide, oaks with Spanish moss frame it nicely, light fades slow. As an man, I savor the simplicity: rig steady, soup hot, no rush. Florida has its quirks, but places like this keep me wandering these backroads.
