Lombana
Super thanks!You gotta drive it for a few minutes they'll sync up.
My first instincts are:
1. Bad connection to the TTPMS receiver near the spare
2. Faled TTPMS receiver
3. Bad connection to the TIM (loose connector from vibration
4. Failed TIM
5. Wire damage to the harness from road debris
This screen shows up if you don't have a TIM and Receiver installed and enable the setting in AlfaOBD. When we were doing the experimentation to figure all of the things out, I jumpered the two connectors in the headliner since I didn't have the TIM yet. I did have the receiver, though. Once the BCM could talk to the receiver, the error went away.
No problems on my boat or Rv tires
2021 RAM 3500 Blackout Megacab
2019 OpenRange 3X427BHS
2020 Jayco NorthPoint 382FL
2021 Luxe Elite 42FL
Look at the link posted a few posts up from yours. The first picture should answer your questions.Before I pull the trigger on this, what is the max psi these sensor can handle as my camper tires are at 110 psi. Also has anyone set this up for a tri axle trailer? Did it work? Do you have a pic of the truck display?
