Crusty old shellback
Now that a bunch of mechanical stuff is done, a switched my attention to programming.
Using the AplhaOBD, I figured out how to hook everything up and got it all working on my laptop.
I changed my tire size to match 34.5" tires I have on it and also changed the TPMS to 30 PSI all around.
Uploaded the changes and saved the file. Thought I was done, went to start the truck and had all kinds of faults that I couldn't clear.
I've been watching Charles Pages on youtube, so I went back to his video on changing tire size. In it, he shows how to clear all the faults. Guess I should have paid more attention. Followed his directions and got all the faults cleared.
I then went and lowered my tires. 40 front/35 rear. I was running at 55 all around as that was as low as I could go without having a TPMS warning. I noticed when I was working under the truck that the outer lugs on the tires were not touching the ground, so way over inflated for a empty truck.
With the lower pressure, tires are making full contact now. I'll see how they do and adjust as necessary.
