Took the Wagon into the local dealership for the first time today.
When I picked my truck up in Washington, two months ago, one of the extraneous non-truck related perks was that Costco sells alcohol. As expected, I bought enough booze to fuel an army before heading back to this funky-lawed state.
Anyhow, the truck started making a knocking, or thump-like, noise from the rear end when you would turn over these last few weeks. Speed didn’t seem to make much of a difference, direction wouldn’t matter. Sometimes it would be fairly loud, other times a lot more subtle. But it was always there, especially if the turn was 90 degrees or under acceleration.
My appointment to get it looked at finally showed up, so I bring the truck down today and am told that it’ll probably take all day due to their workload. I get Ubered home, and within an hour or so they call.
“Sir, we figured out the sound coming from the rear end of the truck. You’ll be happy to know there is absolutely nothing wrong mechanically, and it was a rather easy fix. Under your back seat was a half-gallon of tequila. Whenever you’d turn, it’d slide into the seat rails. Taking it out from under there stopped the noise completely. Feel free to pick up the truck whenever you can.”
…And that was when I remembered putting the one oddball shaped bottle (that wouldn’t fit in the liquor boxes) back behind a seat, so it wouldn’t roll around while I was driving back to UT from WA.
edit: Service record:
Also, since some may ask. The second line item has to do with my reverse guidance lines vanishing. Settings has them on, but they don't display. Advisor said there is an update coming Q3 that should contain a fix.
