Can anyone post what the interior tailgate release switch looks like please
snakedoctor00
Having discovered now I can use my fob to release my tailgate I’m entertaining the idea of adding the interior button. I found my overhead console has a plug with a dummy connector plugged in, meaning it does nothing. I’m wondering if this is where the buttons would be plugged in if my truck had them. I’ve added pictures to show the dummy plug that I found changing my map lights.
If anyone could post what theirs looks like I’d appreciate it. I’ve seen a couple others but having trouble finding good images. I do not have a sliding rear window but don’t mind having the button doing nothing.
That plug is for the rear window open close if you have the slider to my understanding i don't have any spare plugs in my overhead and i have the rear sliding glass
Is your button for the tailgate release up on your overhead console?
The "footprint" is the same on all 2019+.
Okay thank you. Must have been where the lights were throwing me off. Do you know if that plug I have is only for the rear window slider?
my 2019 has the “basic” overhead console (non-LED). My truck did come with remote tailgate , but it’s only got the tailgate release button on the remote. The overhead console only has the switch for the Power rear window. I’m curious if I get the switch set that has the tailgate release it it’s plug and play.
It's in the link I put in the other thread.
Info here (of all threads):
Yes and no, I've been wondering the same thing. Is there a version of the overhead console that has just the tailgate release button but not the sliding rear window or the red or blue buttons.
There is no such overhead console that has the release switch but not the slider switch.
The wiring for the release is not in the connector right? Thats just for the window switch? I have not looked in mine yet to see
The connector for the window switch is only for the switch itself. If you have the base overhead console like pictured below, you will not have the correct connector or linbus wire to plug into the overhead console that has a tailgate release switch- A0C9C618-EFC2-4AF4-A2AA-5D6BE0242757.jpeg
Below is the correct connector that plugs into an overhead console that has the tailgate release- 0186ED14-FAB7-476D-A5D6-D0F32505D029.jpeg
If you already have a premium style overhead console, it will be a direct swap to one that has the release switch. If you have a base console, you’ll need a custom add-on harness to be able to swap in a premium one.
Know anyone who is willing to make the custom harness?
Depending on connector parts availability, I can do it. If there are minimum order quantities on any of the parts, there would have to be more interest. I’ll look into it.
The connector for the window switch is only for the switch itself. If you have the base overhead console like pictured below, you will not have the correct connector or linbus wire to plug into the overhead console that has a tailgate release switch- View attachment 18515
Below is the correct connector that plugs into an overhead console that has the tailgate release- View attachment 18517
